which way should i go
Results 1 to 14 of 14
    MPR FAB southwind011's Avatar
    riverside ca
    Default which way should i go
    picked up a set of twistys and they have the tubes for a one way valve (crankcase evacuation system) and i have new valve covers with no holes.
    should i set up the evac? or a puke tank ? both ways i have to weld in fittings and have lines made.
    Kingman/Golden Vly, Az
    Quote Originally Posted by southwind011 View Post
    personally, i would go with the evac tubes...u already have them & would save you $$$ on the puke tank!!!...just weld some -10AN fittings into the valve covers, either on the ends or the top & get some ss line & your good to go ...just my .02 cents
    FastRat
    Thet tubs are the least expensive way to go and are effective. The puk tank is cool, but requires more work and $$$ either way you're cutting holes in those pretty hew valve covers just depends on if you want to show off your superior fab skills. (Head still a little fuzzy, just messin with ya)
    riverside ca
    do i have to run a check valve (one way valve) or can i run the line straight to the header. i cant find any valves that have threads to put a an fitting to
    Shell Knob, MO
    This is wht you need.
    http://www.jegs.com/i/JEGS/555/52210/10002/-1
    Duane HTP
    Nov 2009
    Langley, B.C. Canada
    by the sounds of it evac
    Senior Member hot-rod 21's Avatar
    Apr 2009
    se michigan
    the check valves are at any parts store STANDARD part#AV7T and i put my own fittings on.
    Senior Member ironman's Avatar
    Clovis CA
    Will the evacs work with water injected headers....or do you have to run em dry?
    Ironman
    Senior Member TahitiRat's Avatar
    Fort Worth Texas
    I have a set of evacs. but I run thru. hull logs will the cheak valves stop the water from geting into my valve covers
    Apr 2009
    se michigan
    Quote Originally Posted by ironman View Post
    Ironman
    Yes, they will work with injected headers, but not with "wet" headers like lightnings, or others that put all the dump water into the exhaust. IMO
    riverside ca
    Quote Originally Posted by hot-rod 21 View Post
    did you weld them on
    Apr 2009
    se michigan
    The air valves have a ridge on the end for a clamp an hose, cut the ridge off. The fitting is actually a water heater gas line fitting, they are steel. I put a bead of high temp silicone around the end put it on and then a small tack weld to hold in place.
    I have this photo, not a real good one i can get a better if you would like to see it better.
    Redding, CA
    You don't NEED to weld anything.
    If you buy the Moroso pan evac system, they come with check valves (that will screw onto your tubes) and push in breathers.
    I used a hole saw to cut the valve covers and it worked great.
    If my new headers had the tubes, I would still be running it.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    riverside ca
    well this is what i did. i built a baffle and welded to the valve cover
