need advise again
Results 1 to 14 of 22
need advise again
    Senior Member hydroman916's Avatar
    Sep 2008
    sacramento
    Default need advise again
    I just spent a sh*t load on my pump, I rebuilt the pump, new wear ring and installed a stainless impeller, I was tryin to correct my out of the hole accel, the boat revs up and dosnt go, if I roll into it its better, so I was told to rebuild and install the stainless impeller, well I did and it does the same mother frickin thing, what should I try or do??????????????????????????????????
    get blown or get blown away
    I have a preloader on mine...seems to help a bit.....
    Made In The Shade
    Custom Window Tinting
    Bakersfield
    Who did the rebuild? Krusn's right, add an inducer and you'll be way happy.
    Sep 2008
    sacramento
    I did it with toms help
    what type of loader do you have? what is the impeller cut? how much horsepower does the engine put out?
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Sent you a PM
    MI
    Get a prop.
    Sep 2008
    sacramento
    Im unsure of what type loader...I just installed an A cut ss imp...engine puts out 741 at 5900rpm...
    Sep 2008
    sacramento
    Quote Originally Posted by sanger rat View Post
    Get a prop.
    Aaahhhh!!!! seen my avatar...I gots one emmm tooo!!!
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Start measuring pressures.
    And check the packing.
    QE 439 Twin Turbo
    Quote Originally Posted by hydroman916 View Post
    What brand impeller? New or used? If used, did you confirm cut size by measuring it?
    Once it hooks up, what peak rpm are you turning?
    Concord, CA
    Default cavitation
    If you stomp on at from an idle, you may be cavitating the pump. Needs to get some flow before it will hook up. What are your rpm's doing? Similar to me, run at 5,900 rpms hooked up, but off idle, it would hit upwards of 8,100+/- till it hooked up, then drag the rpm down to 5,900. I put a rev limiter at 6,000, and it helped. Otherwise I have to roll into it.
    Jerry
    Nov 2009
    Langley, B.C. Canada
    totally going to go with the preloader advice from what i have heard it is the way to go not that i have one but.. no super negatives i have heard
    Senior Member hot-rod 21's Avatar
    Apr 2009
    se michigan
    do you have a f.t.n. set up.? what size insert do you have in?
