My budget (slow) LSx build
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 52
    Senior Member slow67's Avatar
    DFW
    Default My budget (slow) LSx build
    Here is my extremely cheap build......
    Its a 16' 1984 Cimarron SJ. Came from the factory with a 350 and a 12JE pump.
    Two years ago I bought it and stuck in an 8:1 350 with a nice little hydraulic cam (I had the motor sitting around). Had problems with #7, turned out it ended up scoring a cylinder wall. Yanked the motor out and it sat for a bit.
    Plans:
    Rebuild the pump.
    I put a Place Diverter on it 2 years ago.
    Currently wet-sanding it and buffing the hull.
    4.8L LR4 with 320,000 miles (still runs STRONG). I figure the cold block will tighten up the ring seal a little.
    It should turn a B impeller 4300 rpm buy my estimation.
    Also just received my order of stainless in to build some water jacketed headers. (will be about $100 cheaper than buying the PCM manifolds/risers, and look WWWAAAAYYYY better painted or polished).
    Goals are a very reliable family lake boat that does around 60. Keeping the fuel injection. I'm using a 4.8 because it was FREE. Not hard at all to bolt in a 5.3 or 6.0 or 6.2 later down the road.
    The first 2 pics are from 2 years ago. The last one is from over the weekend from wet sanding and buffing (don't think its ever even been waxed).
    Oh and yes, it is wrong hand drive.
ID:	73204   Click image for larger version.
ID:	73205   Click image for larger version.
    Nov 2008
    Fuquay-Varina, NC
    Thats awesome
    '77 Caribbean
    Senior Member CK7684's Avatar
    Minnesota
    Looks almost just like my 16 ft CobraJet...great little boat if youre not looking for super high speed. I really love mine
    DFW
    Oh yeah, it did 60 mph (GPS) with the 8:1 cammed 350, hoping this 4.8 will be just as fast, but be more reliable (EFI) and better economy (I'm saving my 76 Rogers Bonneville for the hot-rod boosted LSx )
    I will be doing the tuning with HPtuners.
    Swollen Member Wasted Income's Avatar
    Central, IL
    Subscribed
    1975 CeeBee Avenger 18' - 6.0L LSx, 12JG
    2002 Sunsation 288
    Central, IL
    Quote Originally Posted by slow67 View Post
    Want to build 2 sets?
    2002 Sunsation 288
    Quote Originally Posted by Storz View Post
    Thats awesome
    x2
    DFW
    It does indeed. I'm pretty sure its a splash. Yours looks good!
    DFW
    There is $700 worth of stainless. 1 3/4" inside header tube, 2 1/4" outside. 3" collector, 4" outside.
    The next pic is my mockup head.
    And the last is my worn out Aluminum flywheel and a flexplate. I will use whichever one my PTO/bolts allow
ID:	73271   Click image for larger version.
ID:	73272   Click image for larger version.
    DFW
    And my welder. Thermal Arc 185.
    Central, IL
    Nice! I am VERY interested in seeing the construction of those headers. Please take and post a lot of pics!
    2002 Sunsation 288
    Menominee, mi UP
    Aug 2009
    Menominee, mi
    great thread to keep my eye on
    Small Block Rockin' SJ-16's Avatar
    Jan 2010
    Far East Texas
    Cool boat. Mine's an '82 with a 350 and Berk.
    DFW
    Quote Originally Posted by SJ-16 View Post
    Nice! Yours appears to be cleaner than mine. Just found a 6" crack in the hull hidden by one of the bunks More glass work
