Thrust bearing failure
Results 1 to 14 of 25
    okie, lake Texoma
    Default Thrust bearing failure
    What do you guys think caused this? I went out yesterday for the first time this yr and drove it pretty hard doing some tuning, then stopped and hit the nos hard for about 6-7 seconds and run up to 125mph and everthing seemed fine till I got back to the ramp and could smell the leaking jetaway fluid.
    I disassembled and found that a piece had broke off of the race and poked a small hole in the back seal.
    Just a weak Bearing?
    It was a ZKL 3307. And had very little run time.
    H8-2-W8
    [email protected] first pass
    okie, lake Texoma
    after looking a little closer I think I see why it failed. For some reason i got talked into running one of these new aluminum spacers behind the bearing instead of the older stainless design. Look at the difference. the stainless is larger OD and requires a larger seal and supports the race better.
    look at the pic of the smaller aluminum one setting on the bearing, its just asking to break the race off (like I did).
    Here's the stainless one setting in the same position. I dont think it would have allowed the race to fail.
    so, moral of the story, you guys with some good hp make sure and dont use the aluminum -smaller spacer.
    H8-2-W8
    Southwest corner AR
    Hass What kind of RPM are you turning?
    WT
    WFL Crew!!!
    Im betting the race was dropped or had an imperfection when the bearing was made.
    okie, lake Texoma
    Quote Originally Posted by widetrack View Post
    hass what kind of rpm are you turning?
    6800
    H8-2-W8
    Southwest corner AR
    Was this side facing the Jet A Way?
    Duh! I know better! bad Question!
    WT
    WFL Crew!!!
    okie, lake Texoma
    Quote Originally Posted by cjaj70 View Post
    If you look at the pic of that bearing , it broke right down to the exact place were the aluminum spacer was touching. That spacer has the edges very rounded off and didnt have hardly any surface area actually touching the race. The stainless one is almost squared off and is larger diameter too. Supports almost out to the edge of that race.
    H8-2-W8
    okie, lake Texoma
    No, this side was facing the impellar.
    H8-2-W8
    Southwest corner AR
    I would think you have the problem solved! It is possible a defect too! WT
    WT
    WFL Crew!!!
    DJG
    DJG is offline
    The thicker wall slinger ring is for an early dominator 12-s. The thinner one is for a late dom, berk, legend. I wouldnt think that was your problem because I have seen 1800 plus hp make many passes with the thin wall slinger. That is with a koyo 3307 though not a zkl.
    X 2 on the Koyo 3307, have a ZLK in the shop with about 3 weeks of use, it's bad enough already I would not put it back in. good thing the rachet lube stinks
    okie, lake Texoma
    Quote Originally Posted by DJG View Post
    Either one of the slingers will fit mine and its a new dominator suction. You just have to have the correct seal for the slinger.
    H8-2-W8
    okie, lake Texoma
    I'm going to try the Koyo this time. and your right about the lube stinking
    H8-2-W8
    B1 Racing cs19's Avatar
    Low quality bearing caused that in my opinion.
