psi
psi
    Default psi
    all this talk about water psi anybody ever check it out of the pump to engine?. p.s. engine is a controlled leak
    Santa Clarita
    This has all been covered in depth here many times.
    Morgan Hill
    Quote Originally Posted by ibelio View Post
    Or uncontrolled...AKA a pressure vessel...Search jet boat water pressure.
    FWIW, they can make enough pressure to blow the welsch/freeze plugs clean out of the block...In excess of 50#...
    GT
    GT
    "Mad" Member Jet Mad's Avatar
    Cape Town, South Africa
    I checked it on my 753 Hamilton Jet(3 stage). It has 2 water feeds to the engine. I used one to the engine with pressure relief valve and the other one I had a Psi gauge on.
    At WOT the gauge went of the scale at 200Psi
    JM
Name:	753 Jet Unit.JPG
