What is preferred?
Results 1 to 14 of 15
What is preferred?
    Southwest corner AR
    Default What is preferred?
    Looking at pictures that are posted I see a lot of boats running mec. fuel pumps not electric pumps! What are the pros and cons or benifits?
    Senior Member NO BUTT NO PUTT's Avatar
    Santee, CA
    You know the mech fuel pump is going to always work.
    Senior Member Ken F's Avatar
    That's why I run Mech. Dependability
    Ken
    ya know i here everyone say mech, but i've never had 1 ele pump failure. i change my filters every season, no matter if they had 6hrs on run time or not, they get changed. i'm runnin 2 holley blacks right now , 1 to feed the motor, the other to feed the nitrous.
    Canyon Country, CA
    the problem isnt a dirty filter, it's moisture.
    as far as the pros and cons. they already spoke for the mechanical above.
    the nice thing about electric is you can run fuel pressure without the engine. good for checking leaks, setting fuel pressure, and even draining the tank. the bad part, read above
    El Cajon, CA.
    A nice thing about electric pumps is there is gas at the carb a few seconds after turning the key on, if the boat's been sitting for awhile with the mech pump you're going to have to crank the engine over for awhile to get the gas to the carb.
    Glendale Arizona
    Quote Originally Posted by Ken F View Post
    Ken
    Yup
    Just give it a couple manual shots on the accelerator pump/pumps before hitting the key, it'll have gas.
    If your bowls go dry that's a different story, but mine will have enough fuel in the bowls to do the above after sitting for weeks and weeks. Takes a long time for all the fuel in those bowls to evaporate.
    Santee, CA
    Yup
    Mine sat for the 2 very long winter months here in havasu. Pumped the gas twice and fired right up. I have only had mech pumps.
    Southwest corner AR
    What type and flow size? 80,110,140 Holley,Carter,ETC? Im going to run a 1050 Dom. Carb. Thanks for the input!
    That's what I've got on mine, a 1050dom. Hi-volume mech pump.
    KEn
    Santee, CA
    Mines a Holley Mech fuel pump. Not sure of the cfm's but im running a Tunnel Ran with 2 Holley 750cfm Double Pumpers.
    Wet
    Wet is offline
    East Hampton, CT
    Quote Originally Posted by NO BUTT NO PUTT View Post
    You did not just say that. They do fail in the diaphragm. I carry a spare just for that added security.
    Santee, CA
    Quote Originally Posted by Wet Dream View Post
    I had one go out once. About 2 years ago.
    Wet
    Wet is offline
    East Hampton, CT
    I run a Holley 130gph and carry a BG for backup.
