Dual 600 carbs
Results 1 to 10 of 10
Dual 600 carbs
    Default Dual 600 carbs
    Has anyone ever run dual 600 edelbrock carbs on a tunnel ram setup sbc? Its a 350, 202 heads(ported), 501 lift cam, dual springs.
    Member 540bahner's Avatar
    Apr 2010
    the potholes osullivan reservoir
    i would'nt use them if i had a choice but if you already own them they can be made two work they're just a real pain 2 tune my .02 cents get a set of holley's you will be happy with them
    Default edlebrock
    edelbrock carbs a real easy to make run if you cant make the edelbrocks run you may have some problems with holleys, i have ran both the holley were a little bit tricky to get them to run right, why do you need a tunnel ram on you small block anyway you will probably have to much carb
    Default tunnel ram
    1200cfm will more than likely be to much for you small block unless it was a big cubic inch small block, maybe a set of 450 hollys would be better
    Default carbs
    But there are some guys on here that know more about this than me they will guide you the right way
    Kingman/Golden Vly, Az
    i agree with Matt...1200cfm on a basicly stock 350 is alot of carb!...u have good heads ...i would "personally" find a Edelbrock RPM Air Gap manif & run a Holley 650/750cfm DP mech sec carb...i think u would be way ahead of the game! ...i know you want the looks, but, you dont want the pain nor the gas mileage!...just sayin' my .02 cents
    FastRat
    Default carb
    It would be better i think just a single carb
    Apr 2010
    hey try the best of both worlds go single top tunnel ram with one 750dp still looks cool and would work great
    Senior Member 42johnny's Avatar
    BERMUDA DUNES,CA
    I have ran many small block tunnel rams, over carbed is a problem...
    202 ported heads will work, just depends on all the factors.
    I have run bigger, but had the heads for it, it all depends on your set up.
    Johnny
    "Blessed is the Nation whose God is the Lord."
    Senior Member IRRebel's Avatar
    Feb 2009
    Casa Grande Arizona
    FWIW, I think you're ok on the carbs and intake selection. The problem is, in boating applications, noone knows how to properly set up the Edelbrock carbs, which are really old carter AFB's. Me included. Maybe can't be done, I dunno.
    All the guys on here that posted would agree twin 600 or 660 Center Squirter Holley's would be just fine on your setup, so why NOT the Eddies?
    Find an old school tuner and get 'em set up properly. I think you'll be more than fine. Difference in the AFB carb and the Holley? Holley you gotta carry a toolbox full of jets and power valves to tune them, and tear them completely down every time. The AFB? Mostly screw adjustments, with the only parts needed will fit in a pill box. Been years since I dealt with them, but they were good enough for the venereable Hemi, I'm sold.
    Ray
    The Other White Meat! Pickle!!!
