Are these BBC heads any good?
Results 1 to 14 of 14
    Senior Member PonyFiveO's Avatar
    Feb 2009
    Southbay to the Central Valley
    Default Are these BBC heads any good?
    Howdy,
    So after sitting in my boat pretending I was at the lake after going through my flooding carb issue, I pulled off a valve cover to see what kind of heads I am working with...
    • 10114156...91-up...oval...OPEN...Gen.V & VI 454, 118cc chamber
    So, are these any good or are they severely limiting any potential of gaining horsepower in the future?
    Thanks!
    Cas
    Cas is offline
    Angry American Cas's Avatar
    Those heads are a low performance head made more for low speed RPM and torque from a Gen 5, if I remember correctly. I've never had a Gen 5 but from what I understand, there aren't too many parts that can swap between the Mk4 and Gen 6.
    Apr 2010
    Rocklin, Calif.
    Default Gen-6
    if it's a low deck you can use anything -the timing gear cover is differnt and the oil pan is different
    Apr 2009
    Kinda makes it easy! So you dont have to think much!
    Ford Power!!
    Cas
    Cas is offline
    oops, I just read what I typed and I think I made it sound like parts can't be swapped between the Mk4 and the Gen 6.
    thanks for setting it straight though, it's good to know.
    LAID IN MEXICO
    santa paula, ca
    Default gen 6
    oil pan and timing covers are different. as far as aftermarket fun, everything else will work on either. mark 4 cams will work in gen 6 too.
    Quote Originally Posted by PonyFiveO View Post
    Howdy,
    Thanks!
    Those are "peanut" port heads, not for performance. Before you consider swapping heads, check the block casting number as the Gen 5 blocks are not good for putting MK IV or aftermarket heads on. Gen 6 works with better variety of heads.
    Don't plan on just adding a different set of heads and gaining a bunch of power, the cam needs to match your application to make it all work
    Cas
    Cas is offline
    Quote Originally Posted by nelson#109 View Post
    By the number on his heads, he has a Gen 5. Is everything interchangeable with the Gen 5 also?
    Feb 2009
    Oh Goodness! I honestly did not realize there were so many differences from one BBC to another. Maybe I should have just stayed a Ford guy
    That's not 100% true, as he correctly stated, the 156 casting was used on Gen 5 and Gen 6 blocks.
    Also, as I stated above the Gen 5 does not like aftermarket or MK IV heads, there are water sealing issues.
    Cas
    Cas is offline
    got it, thanks!
    i have a set of gen v heads part # 088 Rect port.they have already been converted for an adjustable valve train.if your interested
    Jul 2014
    Bakersfield
    Do you still have these heads
    6612036777 DannyMcchristian
    Sep 2014
    Quote Originally Posted by Super Duck View Post
    More than 9 years ago. I doubt it.
    Sent from my SAMSUNG-SM-G891A using Tapatalk
