updating interior
Results 1 to 9 of 9
updating interior
    Junior Member sandman's Avatar
    el cajon, ca
    Default updating interior
    Ok guys here we go again busted my ass this sunday roughing in the new boxes, sidepanels and buckets oh still need to make my seat bottoms for the bench and just need to seal them up and start the search for a good but fair upholstery shop any sugestions in east county san diego would be appreciated. Also was wondering if any of you gooroos have heard of rhino lining the wood before upholstery saw a guy post his seats after treating them but he never posted final product so i never got to see if it worked out. What do you guys think of that idea?
ID:	73502   Click image for larger version.
ID:	73503   Click image for larger version.
ID:	73504   Click image for larger version.
ID:	73505   Click image for larger version.
    Kingman/Golden Vly, Az
    very good looking interior ...nice job...i would seal all the wood with Thompsins Water Seal before doing the upholstry...also...u might check with Neil (sdpm) here on the boards...he lives/works in SD & can prob help you out or recommend someone to you ...keep the pics comming!
    FastRat
    I just did my seats from scratch, I did like 4 coats of resin on it, thinning it on the first few coats to allow it to soak in. I couldn't find any cheap places in north county, I checked every where.
    el cajon, ca
    FastRat
    Thanks Fast Rat
    I will keep up the pics as progress is made. Ya I gotta seal all this stuff I was gonna resin it but its such a pain in the a-s I think im gonna head to west marine to see what they have to offer.
    Sandman
    Anaheim/BHC- the Shack
    A little advice from what I've learned re-doing my interior. Fiberglass..... use it on ALL corners and anywhere a joint will be stressed. Also reinforce anywhere wood meets at a right angle with a 2x2. After you're done glassing everything, resin wash all the wood. You'll be surprised how quick the wood goes away if you don't.....
    Oh, and all the sharp edges, corners and angles? Round them all off. If you don't, they'll do a couple things after you spend all that hard earned cash on new vinyl....... cut through foam and create a sharp edge that will easily split vinyl. It'll also look a tad funky having sharp corners show thru otherwise smooth upholstery.
    el cajon, ca
    Quote Originally Posted by slowride View Post
    10-4 sounds like great advice i still have some reinforcing to do on the buckets as well so should not be tough to handle the rest thanks
    sandman
    1/8 qtr round with router, makes beautiful edges. Multiple coats of thinned resin, allows penetration of the wood, and also keeps the weight down. Looks great!
    el cajon, ca
    Thumbs up
    Was thinking about using a router thats the cleanest way to accomplish this task
    Alamogordo NM
    When I did my new interior I resi washed it (very very thin), laid down some cheap azz cloth from wal mart, and applied a thicker (but still thinned to about half) resin. You will be amazed how ridgid it makes everything, plus the resin cant ever go anywhere if you use cloth, I think it will last as long as the boat does.
    The cloth from wal mart is something like four dollars for eight sq ft, cheap compared to resin.
