First outing of the season
Results 1 to 14 of 17
    Denton, TX
    Default First outing of the season
    It went... well so so.
    It's a SBC,177 Blower, dual Carter's(400 CFM) running .395 jets. timing 6* static 30 Total. I noticed when coming up on boost fuel pressure drops from 6 to 3, engine starves and develops a "Lean Pop" Plugs don't look the greatest. Is the engine running the carbs dry? Fuel pump can't keep up? It's a Holley Electric Blue (110GPH) Also the fuel pressure seems to bounce somewhat 5.7-6.0 would a regulator with a return line fix this? I am thinking of going mechanical on the fuel pump.
    On a side note, after a run the carbs and carb adapter have frost on them and are cold to the touch. good?
    Kingman/Golden Vly, Az
    Quote Originally Posted by Btnhtillidie View Post
    a suggestion, if i might...take those Carters off & put a single Holley 750/800cfm DP mech sec on it! ...it will run awhole lot better & you will be alot happier!...also...the Edelbrock or Carter HP mechanical fuel pump is a good choice...on your side note...my blown alcohol SBC would ice/frost the hat after a run (Dragster), so, i dont think you have anything to worry about ...this is just my .02 cents of what i would do
    FastRat
    Senior Member cave's Avatar
    Mesa, AZ
    FastRat
    I've been down this road. My solution would have been a Clay Smith fuel pump and a Endely check valve set up at 7 lbs on the end of a fuel log returned to the Y if you have 2 fuel tanks.
    One thing that I had wrong with my blower set up was my J tubes in my fuel tanks. They were 1/4" ID. I made new ones that added .125 / 1/8" making them 3/8" Added a Aeromotive 1000 electric pump and called it a day. Wasn't cheap but neither was my motor.
    If you could spring for a Clay Smith Mechanical and a decent Return type regulator and return to your y, You may be set. Save the holly for your nitrous
    Jus Kidding, toss the Holly..
    Takin it home
    Denton, TX
    I'll look into the Clay smith, Thanks.
    As far as the single holley. I dare to be different! lol
    Team CJ460 Just Electric's Avatar
    granada hills
    hey robert i have a nice holley dp 750 for ya ready to go with some nice big jets in it
    Anaheim/BHC- the Shack
    As I remember, Carter's were essentially a vacuum secondary carb and it probably has the same shortcomings in a boost situation. I don't even know HOW you would boost reference one. So as you come onto boost, would the carbs see greater vacuum shutting down the secondaries that started to open under low vacuum? Sounds like that would cause shooting ducks.....
    My .02
    I think you should be running more than 6 lbs of fuel pressure to start with, but have no experience with what Carters will accept.
    With Holley carbs, I like to see pressure around 9 - 9 1/2, and not dropping below 7 lbs on a forced induction engine.
    I had a dual fuel pump setup on my turbo engine, mechanical and a Holley blue, parallel into a fuel block, with dual check valves. Basically either fuel pump would run the engine on it's own, but if one failed I would not melt the thing down.
    Denton, TX
    Quote Originally Posted by slowride View Post
    My .02
    Pretty Positive there Mech. Secondaries i believe the number on the carbs are 9410s
    They don't have a weighted air valve on the secondaries?
    Van
    Van is offline
    Default Carter carbs
    Check the needle & seat assembly, stock is a very small orifice and with a blower it can suck the carbs dry. The blower carbs should have a larger orifice
    Van
    Denton, TX
    Default everyone likes pics
    Denton, TX
    granada hills
    buena vista looking a little stagnet in a few of those pics
    Denton, TX
    Quote Originally Posted by Just Electric View Post
    no one was running. We got there on thursday no one boat in sight. Hell it was only our group and one other.
