Clay Smith Fuel Pump
Results 1 to 11 of 11
    415 M3
    So Ca
    Default Clay Smith Fuel Pump
    Where can I get one for a good price? Direct they are $125. Not knocking the price, just lookin for the best deal. Thanks fellas.
    Colfax, Ca
    Buy it, they are worth the money!!!
    Bullhead City, AZ
    That is a good price, look at a Holley 130gph+ pump at Summit.
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Senior Member Futs's Avatar
    Orange CA, Big River
    pm superdave013 here on the boards. Sweet performance
    Feb 2009
    So Cal
    Default Price
    10 bits is pretty cheap , think about all the stupid bling on a boat that costs way more than that. Here you're getting something functional
    Quote Originally Posted by gunslinger View Post
    Glendale Arizona
    That's a good price. The one that fits my Ford costs $150 (of course its more, it's a Ford). I called around to a few of the parts houses here in Phoenix and nobody sells the Clay Smiths. Not sure why, but there ya go. Have to order from Clay I reckon.
    Senior Member 787chuck's Avatar
    MorePark
    look at the carter pump 160gph #10 fitting in and #8 out and i think its less $ the pro gas flats use
    Junior Member J540's Avatar
    I have one but I mite need it. Ill let you know, But you can get the Edelbrock/ Holly # 510-12-454-20 pump its the same type it has -10 / 1/2" in an out its there Gas/Alk pump I have one on my motor rt, now with no reg, feed n my tee tank for my Injector pump, It works fine and I used it on my carb 540 12.1 motor with no probs, at all. But the C,smith pump is $125 and thats not bad at all. You are not going to save much anyway. The E,brock pump is plated chrome and looks good, and flows 170gph at 8 psi. Look at jegs not summit. i'v had the same pump on my Blown motor for 6yr, and its still fine.
    Here are a few pic's. If it looks big thats because it is a -10 out to a -12 line fitting
Name:	pump1 (Medium).jpg
ID:	73928   Click image for larger version.
Name:	pump2 (Medium).jpg
ID:	73929   Click image for larger version.
Name:	pump3 (Medium).jpg
    Senior Member Big River Dog's Avatar
    I have a used Edelbrock Mechanical Fuel Pump for a BBC. It's the large rebuildable type. I also have the cam push rod and a Holley Regulator. All of it $50.00
    Anaheim Hills
    They must have just went up. I paid $115 back in June/July direct from Clay Smith.
    Haven't run it...yet, however I hear they are the shiz and well worth the money.
