Pump shoe
Pump shoe
    Member TV334's Avatar
    Gillette WY
    Default Pump shoe
    Hey guys what do i use to fill in the dip in front of my pump shoe. It had some stuff that looked like bondo or evercoat. Just wondering what would work best. The other stuff was cracked so i ground it out now i gotta fill it. Thanks.
    The intake probly needs to be pulled and re-set. The corner bolts were never installed, likely causing the intake to seperate from the hull. The right stuff is called sea-going epoxy.
    Senior Member watergun4u's Avatar
    Visalia, California, United States
    X2,, I would not try and fill it in, you need to pull the intake and reset as stated!!!! otherwise it will most likely leak!
    Angier, NC
    x3 or marine tex same stuff reset for sure all bolts in place is safer
    HOT ROD BOATS
    ANGIER, NC
    pump & parts
    fiberglass work
    s.s. hard lines custom made
    pretty much anything
