Old vs. New Place Diverter
Results 1 to 14 of 16
    Senior Member stc315's Avatar
    Yuma, AZ
    Default Old vs. New Place Diverter
    I picked up the old style place diverter. It was a smokin deal on a freshly powdercoated unit. My question is, will that reverser create that much drag? Should I spend the $250 to get a replacement nozzle? The boat went 92 with a 540+cid bbf and jc with new style pd (previous owner). I will be running 650hp 501 BBF with the same jc but with the old style pd. What do you guys think?
    Show a pic...I believe some of the older ones can be cut off or modified.
    Made In The Shade
    Custom Window Tinting
    Yuma, AZ
    pic from when I bought it (on previous owners pump)
Name:	old place diverter.jpg
    Senior Member nick's Avatar
    Fullerton & Water Wheel Resort
    I'd be interested in hearing the answers to this one too. I have the same old school diverter with the obnoxious reverse part.
    Last time I was down at MPD, Jack did suggust I trim some of the lip off to reduce drag.
    Angier, NC
    would be good idea to mill down flush like newer ones if ur worried about drag
    HOT ROD BOATS
    ANGIER, NC
    pump & parts
    fiberglass work
    s.s. hard lines custom made
    pretty much anything
    Yuma, AZ
    Is it just as simple as whipping out a hack saw, or is it something I should take to a machine shop?
    Kingman/Golden Vly, Az
    Quote Originally Posted by stc315 View Post
    its that easy ...also, a file!...there was some pics somewhere on here as to where to cut etc
    FastRat
    Yuma, AZ
    I might do that. I'm still leaning towards getting a new nozzle end. I may cut this one if I get it on the water before I can get the nozzle.
    Anaheim/BHC- the Shack
    From what I've seen of the nozzles of boats on plane, a ride plate would reduce nozzle drag more than trimming the reverse chute.
    Any pics out there of people that did remove material from their reverse chute?
    Senior Member Amango's Avatar
    Sep 2009
    Quote Originally Posted by nick View Post
    Here is the link. I cut mine down never ran it yet!
    http://www.performanceboats.com//sho...ghlight=amango
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    not good pics but milled it basically off, blocked it off and put a neutral on the bucket
    Found a decent one
ID:	73821   Click image for larger version.
ID:	73822   Click image for larger version.
    QE 439 Twin Turbo
    The ride plate in this pics looks like it is keeping the nozzle form dragging and probably would without trimming the chute.
    Yuma, AZ
    I don't have a ride plate. I was thinkin of doing one of those bolt on shoe/ride plates. But I'm not sure if the added drag would be worth the gain. Guess there is only one way to find out. Unless someone has used a bolt on ride plate before. I guess I could always go split bowl and use a pd droop with bolt on plate. Decisions, decisions.
