Pump brace pictures
Results 1 to 14 of 18
Pump brace pictures
    Done.... So.Bay*310*'s Avatar
    So.Cal
    Default Pump brace pictures
    Did a search, did not really find any clear visual pictures of ideas to make a pump brace. I'm thinking of making one after Memorial trip out, would like to get ideas. Post what ya got. Thanks.
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Duane at HI-Techperformance can set you up with a pump brace
    Here are some pics of braces
    http://www.hi-techperformance.com/CustomBoats.htm
    I got my inside the boat pump brace from Duane. Try a search for " let's see your pump brace" there are some good ones there.
    Senior Member cave's Avatar
    Mesa, AZ
    There was a good thread on here a year ago. it had a few different ways to go. I posted some of Duane's stuff up.
    Some good ideas that popped up in that thread. I ended up making my own up out of some 1/4" aluminum. Turned out OK.
    Takin it home
    Mesa, AZ
    Awe Here it is
    H2oMoFo Remember this ???
    http://www.performanceboats.com//sho...ght=pump+brace
    Takin it home
    Anaheim Hills
    I ordered one from Duane.
    TEN THIRTY ONE RCB19's Avatar
    You probably don't need one in the Miller Nandi but the extra insurance can never hurt.
    RCB
    Senior Member SlowRyd's Avatar
    Houston Tx.
    Not the trickest but heres ho I did mine (Before anodizing)
    San Diego, CA
    pump brace.
    Boat 405.
    Senior Member 76 Bonneville's Avatar
    Valley Center Ca
Name:	Pump Brace - Milkshake 002.jpg
    Lookin' for answers. Pizzy's Avatar
    Tucson, AZ
    If the suction housing were to seperate from the hull enough to leak what is the proper way to fix the leak? Have the suction housing reset into the hull? Just curious because I noticed my daytona does not have any bracing and I had water in the bilge area under the motor when I took it out last.
    Boat 502 76Miller's Avatar
    Huntington Beach, Ca
    Really more for a tunnel type hull.
    Tucson, AZ
    Quote Originally Posted by 76Miller View Post
    Okay so are you saying that even though my pump is set back with a ride plate and snoot, that this issue shouldn't apply to my boat? Sorry for the questions just new to the game is all.
    Anaheim Hills
    Quote Originally Posted by Pizzy View Post
    How big of a leak are we talkin here?
    1st off your suction housing won't separate from the hull as its bolted to your intake and the intake is connected to the hull. If that is the issue, take care of that immediately!
    Your reason for a leak could be a number of reasons. Next time out, look into the bildge and try to see where its coming from. Check you intake bolts, suction gasket and transom plate 1st. Lack of a pump brace is likely to not be the reason for a leak.
