LODBRS Approved Rope Deflector
    Back into Boats Beal Motorsports's Avatar
    Dec 2009
    Kansas City
    Default LODBRS Approved Rope Deflector
    What did you guys build your rope deflectors out of? I read the rule book and it stated " 3/4" x .049 or stronger setup at around a 45 deg angle". Doesn't mention material.
    I was planning on aluminum. My old one was stout, but not quite 3/4".
    Shannon
    TEN THIRTY ONE RCB19's Avatar
    Most of us use 3/4 aluminum pipe and bend it to fit the application.
    RCB
    San Diego, CA
    I use 3/4" aluminum pipe. But I use .065 wall because with the bender the thicker wall doesn't kink, like the thinner wall .049. Secure it at each end and your done.
    Boat 405.
    Dec 2009
    Kansas City
    Sounds good. Would someone mind posting a pic of theirs?
