Grates?
Results 1 to 10 of 10
Grates?
    Senior Member 2002CP19's Avatar
    Lake Arrowhead/Lost Lake
    Default Grates?
    What is the best grate to run in a GTH intake? 18' CP LIGHT lay-up! 650-750 hp.
    Thanks Brandon
    Quote Originally Posted by schick View Post
    Hold it firmly on the ground, a few pelvic thrusts should do the trick. If not repeat till satisfied!
    Wow! Nothing huh?
    WFL Crew TINTDESIGNZ's Avatar
    East Texas
    Quote Originally Posted by 2002CP19 View Post
    Thanks Brandon
    do you mean grate or LOADER? A grate keeps debris outta your pump, a loader-well forces water into the pump.I'm sure theres other questions about your setup to answer the question correctly. Maybe one of the CP guys will chime in!
    Quote Originally Posted by TINTDESIGNZ View Post
    Ya loader/grate.
    if its a lowpro gth, you're better off having 1 built to get the right angle at the impellor face. a basic loader could be modded, but that shiat is dangerous, a loader is no place to experiment your welding skills
    Yep lowpro GTH
    if you're near a reputable pump shop, i'd have 1 built then. where in the world are ya?
    Just curious if to see that GTH intake if you have a pic and what degree it is? Tom
    I'll post one tonight or in the morning.
    Thanks!
    Tempe/Big River
    they range all over the place, between the two 18's that im familiar with they have two totally different loaders, ones a heavier boat, ones lighter, it all depends on application, ET, MPH, etc..... id say call MPD for advice hes put 10 different ones through our boat and they all acted a little bit different.
