Dyno how much
Results 1 to 14 of 22
Dyno how much
    Senior Member UNASHAMED's Avatar
    Sep 2008
    Tucson, Az
    Default Dyno how much
    Just curious how much a dyno run is everywhere else. Here at Larry's its $600 for a day for a BBF and $575 for a BBC
    "Don't make me get my penguin"
    Atlanta TX
    Around 300 for a day. Conservative DTS dyno.
    Santa Clarita
    Most places in So Cal run about $500 to $600
    Senior Member swtd's Avatar
    Sep 2008
    beaumont ca
    Quote Originally Posted by UNASHAMED View Post
    was told 2 diffrent sources in riverside 800-900 for a day! DAMN.
    Quote Originally Posted by cpjet View Post
    Sorry man, don't take this wrong, but that phrase just cracks me. EVERYBODY says the dyno they tested on is "conservative". If that's true, it means either the dyno is not accurate or their motor made less power than they think it should....
    Torque is torque, HP is calculated from that and then corrected to standard air. An engine on an accurate dyno (using the same test) in AK in January should read the SAME corrected HP as the same engine on a dyno in TX in July.... The dyno is either accurate or it's not.
    Now I've heard stories of unscrupulous operators fudging numbers to make more HP... don't think I've heard anyone fudge them to be less. But as always, YMMV...
    To the OP, dyno time is about $600 a day at the shop I use.
    David I think what he's saying is it's $ 300 on a conservative dyno, but if you want a higher reading number they'll loosen it up for you but that's $ 500 for the day
    S CP
    Canyon Country, CA
    S CP
    Now that was funny
    Default dyno time cost
    I recently took my new motor to a dyno. first time ever for me. he charges by the hour. my cost was $400. what I learned was enough to possibly save me from running an incorrect tuneup, and destrying my motor. I learned that my motor makes max torque of 802.3 at 5100 at 26 degrees total timing with air fuel ratio 15.9.
    max hp turned out to be 843 at 6200 at 28 degrees timng.
    had I not tried this dyno thing, I would have gone out and tried to run 38 degrees and mabe hurting my motor. money well spent.
    Swollen Member Wasted Income's Avatar
    Central, IL
    Quote Originally Posted by OkieDave View Post
    15.9 AFR????? Was that a typo I hope? I know lean is mean....but yowzer!?
    1975 CeeBee Avenger 18' - 6.0L LSx, 12JG
    2002 Sunsation 288
    Quote Originally Posted by Wasted Income View Post
    Lean is mean then POW !!!!!!
    Interesting #'s on that engine....wonder what it is?
    Dyno money is money very well spent.
    S CP
    Glendale Arizona
    Ya know.........it's amazing. I've done searches several times for an engine dyno in Phoenix. The only thing I can find is a chassis dyno. There are a number of them, but that does me no good.
    Is anybody aware of a shop that has an engine dyno?
    I think I smell a business opportunity in Phoenix.
    I can't believe that with all the people into motorsports in this area and no dyno.
    Sep 2008
    Tucson, Az
    Here ya go buddy. Steve 480-294-4026 or az speed and marine Jim 480-753-3208.
    Glendale Arizona
    There goes my business opportunity.
    Thanks for the contact info.
    Dan
    Default lean
    "15.9 AFR????? Was that a typo I hope? I know lean is mean....but yowzer!? "
    "Lean is mean then POW !!!!!! "
    I know, its funny the mixture at next rpm above and below were in the lower 14's. in the 17's at 4600 and 13.72 at 5800. no carb changes.
    motor is BBF. 557", 13:1, FRP SCJ heads, .685 solid roller cam with 1150 dominator carb.
