Inducer Impellor
Results 1 to 14 of 31
Inducer Impellor
    Dec 2009
    Northern Indiana
    Default Inducer Impellor
    Question for those who have been there and done that. While inspecting pump impellor on 12JG pump I noticed a very tiny amount of movement of the inducer impellor on the shaft. Tiny as in being barley noticeable. I was told the pump was fresh when I bought the boat late last year. Boat is used mainly for pleasure. If I understand correctly the pump impellor seats against the inducer impellor, holds it against a shoulder on the pump shaft and is driven through a key. Any thoughts as to next step I should take?
    High Performance Marine ARS Marine's Avatar
    Feb 2009
    Morris,Illinois
    At least pull the bowl off and check the impeller nut to make sure its tight!!
    You are correct the impeller clamps up against the inducer, There should be no movement of that inducer !!! If the impeller nut is tight you should be able to install a shim between the imp and ind to clamp everything tight.
    Hope this helps.
    George Pataki.
    Senior Member cave's Avatar
    Mesa, AZ
    George, What advantage or disadvantage would the be to shim between the impellar and the induser?
    Takin it home
    Feb 2009
    Morris,Illinois
    If the shaft was machined to deep, it will not clamp up the inducer.
    San Diego, CA
    He's talking a small shim. Very small, like .005 or .010 probably. If more than that is needed there is a problem with something.
    Boat 405.
    Dec 2009
    Northern Indiana
    Thanks for the response. I have not pulled a pump apart before but figued that your suggestion would the the next step. Time to gain some experience.
    show your tits topless000's Avatar
    i have taken them out of three different boats and the same results. the boats run better. Everything the same on a tx 16 i pulled the pre impeller and made a pass on the track and gained 2 tenths. on a daytona it ran the same et but gained 5 mph. And witness it on a place craft at the track pulled it and gained 2 tenths. i am not a big fan of them at least in my experience. just my .02
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    There are different inducers out there
    The new style is much better then the older ones
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    Who makes the newer ones??
    These colors don't run BLWN BUX's Avatar
    Sep 2008
    Riverside, CA
    If the nut is loose, then check to make sure the nut is the correct one for the set-up.
    If I remember correctly the stainless impellar uses a SST nylock and the aluminum impellar uses the alum. nut
    The Aluminum nut will come loose agains a stainless impellar.
    Norco
    From what I understand DPS is the only inducer to use. Make a heck of difference in my boat. It takes off now. LOL
    Quote Originally Posted by TRG View Post
    The HM is the latest inducer, much smaller hub area, and nicely shaped blades
    okie, lake Texoma
    I have a new HM as well as a DPS. Last time out I changed over to the HM and the boat didnt like it. Came out of the hole the same but felt like it kept the azz end of the boat sucked to the water and scrubbed off quite a bit of speed.
    And yes , thats the only change since last outing.
    As for now the DPS is back in till I have more time to evaluate the HM, and why it did what it did. May be able to change up the hardware to compensate but I bet it wouldnt run any better than the DPS in the end.
    My.02
    H8-2-W8
    [email protected] first pass
    have used different ones, liked them all, most of the dps i used took the time to modify them, cut the back off into a taper and made a matching taper spacer to flow into the impellor.
