Pump Question
Results 1 to 13 of 13
Pump Question
    Anaheim Hills
    Default Pump Question
    At what point should a stock jet pump be modified for big hp? And....what should be done? I'm concerned about potentially breaking a stock pump with "too much power".
    What is too much power?
    Nov 2009
    AQ shaft and stainless impeller and a pump brace anything over 700hp to be safe oh yeah and probably thru bolt a loader grate! I like to be SAFE.....
    Anaheim Hills
    Quote Originally Posted by wicked performance boats View Post
    what is too much power?
    950-1000. Just curious if it possible to do serious damage with that. Obviously an aluminum impeller is out of the question.
    Anaheim Hills
    Ive got the pump brace and thru bolt loader down so far. Is stainless mandatory? There kinda out of my budget, I was hoping bronze would do the job.
    The Right Coast/SE-PA
    Rumor has it, Bronze can easily handle those numbers + some.
    Anaheim Hills
    Ive heard the same but want more input/ideas/suggestions. My last engine made 800hp and I ran a bronze.
    The bowl is another question. Are there any bowls I should stay away from?
    Honestly, at even 1000 HP I doubt you could hurt any of the "name" bowls > Berk, AT, Aggressor, Dominator. I would however switch out any bowl bolts to studs
    Believe I've read here, there was some casting flaws with a few Aggressor bowls but those were behind engines that made a few serious thousand HP.
    Nov 2009
    I would still run a good shaft! Bronze would probably work. I have never ran a bronze impeller. I would try it out. I hope you don't have an aluminum in that Ultra tunnel
    Your way cool with a Mag Bronze, 17-4 shaft. Bowls you want flow rate, 1st. Aggressor, then a Berk.... so pick your budget....
    I run one pops pumps 1000hp-1200hp bronze mag aaa never had a problem in 5 years works very well
    Anaheim Hills
    I appreciate all input! Please keep it coming.
    Canyon Country, CA
    Sounds like you got a serious motor, any details on it?
    You ought to bring that thing out to the drags once. It's a good place to dial in a setup like that. As far as the MB, from what I've been told you should be fine. But I would call a reputable pump builder to be sure.
