21 ft Bahner speed?
Results 1 to 14 of 18
21 ft Bahner speed?
    Default 21 ft Bahner speed?
    I am looking for 75-80 mph out of my bahner, i lost the motor that was in it and would like to hear some Ford only engine combos people are running and getting that speed out of a similar boat....
    Ladera Ranch
    To make a big boat like that do 75 you are looking to make 650+ hp, maybe more. Good luck having someone spec that combo out for free. Look up LakesOnly. He knows the Fords, and while I dont think he will give you a free combo, he can build a nice stout motor package for you.
    Senior Member scottietwohoty's Avatar
    La Mirada, CA
    Mines kinda the same thing and I don't think the hull will hold 80!!
    The boat was not made to go that fast. IMO. But good luck!!!
    Bahners were good hulls back in the day, actually it depended on the mood rod was in that day.................ya thats a heavy boat to get that speed out of, but its very possible, mines a stock 460, with a tight dom pump, and im getting right at 60. Throw a shitload of money at it..............
    Quote Originally Posted by AzEliminator View Post
    Maybe bad mood, Im picking it up tomarrow after new stringers, floor, bottom cracks fixed, and the bottom gel coated again, color sanding the boat and new throtle and steering cables....4700.00 later im looking at a engine combo 532 bbf 631 hp and 650 ft lbs...... i have a 12jc i need to upgrade to the split bowl and droop snoop, thats what im up against....
    Southwest corner AR
    Check with Sleeper CP he has had some good Ford combos!
    Quote Originally Posted by scottietwohoty View Post
    probaly right, thats why i re did the bottom, stringers, and bulk heads.....
    Mighty Member BoobyBouncer's Avatar
    Quote Originally Posted by 81bahner View Post
    how much for that engine and where??
    Default engine
    I have had many engines built by these guys, ford performance soulitions....aka fps....and from carb to pan w/dist and dampner.....$ 7400.00
    Ladera Ranch
    If its a heavy boat go overboard on the power. My 21 has 800 hp and im in the mid 80's...Not sure how heavy it is but it likes going fast. Just be careful and approach the faster speeds with caution.
    Banne'd Cobra1's Avatar
    Think OUTBOARD!!!
    Ladera Ranch
    Quote Originally Posted by Cobra1 View Post
    Think OUTBOARD!!!
    No thanks. You know why? Cuz from a dead stop or even a cruise I will walk away from you-no doubt about it. Maybe your outboard is more efficient on fuel, but my big block is way more fun. I can pack 5 people in my boat and still get on plane with no noticeable difference. I know for a fact that you cannot. Glad you like yours though, but until you've had a big hp jet, you just wont get it.
    true..........
    Default just cant do it
    thats cool you like your outboard but im a big block ford guy maybe if ford put a high winding small block in one, but thanks anyway.....
