Removing the Impeller from a Jacuzzi
Results 1 to 3 of 3
    Senior Member Swain's Avatar
    Aug 2009
    Default Removing the Impeller from a Jacuzzi
    My boat has a Jacuzzi WJ and I want to change out my impeller.
    How hard is it to do and do I need any special tools?
    Easiest way to do this.
    Jason
    Member TrynPas's Avatar
    Litchfield Park, AZ
    this doesn't answer your question, but it might come in handy.
    You done got my kentucky ass all confused!!!
    Denton, TX
    Quote Originally Posted by Swain View Post
    Jason
    Depending on how many years it's been on there it may be a PITA! No special tools required. Take the bowl off, you will see the Impeller nut and set screw, set screw comes out first then the nut. I would let it soak in some oil over night though. after the nut comes off, try pulling it off, FYI it has a key way cut into it so dont lose the key!
    Here check this out...
    http://www.performanceboats.com//showthread.php?t=21599
