Cleaning out a fuel tank??
Results 1 to 12 of 12
    Senior Member sleekcraft137's Avatar
    Star, ID
    Default Cleaning out a fuel tank??
    Any suggestions for cleaning out a fuel tank that I found dirt and sand in without removing the tank? I replaced my fuel pump last night and added a fuel filter between the tank and the fuel pump. My boat quit running today, i pulled the filter and it was packed with dirt! I changed my fuel lines a few days ago with clear lines, i can see a ton of dirt in the line. any suggestions?
    Sep 2009
    Winter Haven, Fla.
    The old fashioned way, jack up the front of the boat for better drainage, open up the drain as much as possible and flush into a bucket, pan, etc. until no more trash comes out.
    Hard to agitate or slosh around, be very careful if using gas for fire hazard !! Safer to use detergent and water, then some alcohol with the gas to absorb the moisture and water remaining.....
    Still won't get it all, so use a very large filter and check/clean/change often.
    Hopefully somebody has a better easier way !!!!
    Without removing tanks
    Star, ID
    Quote Originally Posted by rotorrider View Post
    unfortunately there's no drain on the bottom of the tank, just the fuel line outlet on the top of the tank. I guess i'll just buy a HUGE ass fuel filter!
    Member TrynPas's Avatar
    Litchfield Park, AZ
    can't you use one of these? it says you can use it for 'solvents and oils'
    http://www.harborfreightusa.com/usa/...ubCategoryName=
    You done got my kentucky ass all confused!!!
    Star, ID
    Quote Originally Posted by TrynPas View Post
    SCORE!! i didnt even know that was an option. I'll run by harborfreight tomorrow!
    New Jersey
    Be careful what you power the pump with!! I would strongly suggest using an air power drill if you decide to use that pump. If you are pumping fuel you should not use an electric drill - lots of sparks at the brushes in the drill. Working with gas there are always fumes, and if the fumes and the sparks come together you can have a fire and/or an exposion.
    Be safe.
    Doug
    Dallas, TX
    That looks like the clear hose from the plumbing section of a home improvement store. It that stuff rated for fuel?
    Anaheim/BHC- the Shack
    I use one of the small impulse type fuel pumps. Hook up a large filter to it, run the hose down thru the filler and pump it out. You can also set it up to recirculate thru the filter to clean the tank without removing the fuel.
    Glendale Arizona
    Quote Originally Posted by Real McCoy View Post
    Be safe.
    Doug
    Amen Doug.
    How the hell did that much sand get in there? Got a pissed off x....
    Made In The Shade
    Custom Window Tinting
    Star, ID
    its rated for chemical, im just using the clear hose so I can see what the hell was going on with my fuel. I'll most likely switch it out after the prob is fixed
    Star, ID
    i just bought the boat, you should see how much was packed in the filter!!
