U-Joint Noise
Results 1 to 6 of 6
U-Joint Noise
    Sep 2008
    Yuma, Az
    Default U-Joint Noise
    I ran my boat yesterday and as I was making my way back to the dock, I heard a knocking noise at about 800rpm, when I would give it gas at 1krpm, it would go away.
    I did noticed my sons little car had made its way under the pan, so I thought it was just vibrating, so I didn't think to much of it.
    I went home and took off the drive line and the noise was gone. I spun the pump and it was smooth with no noise. The only thing I could think of, would be the u-joints. Can the u-joints make a slight knocking sound if not greased enough, even at low rpm?
    boatless....
    Texas
    If you have any doubt, for the price of some new u-joints i would just replace them. The needle bearings just wear out after a while, replacing them is cheap insurance.
    Nice!
    Shell Knob, MO
    Sounds like you just had it idling too slow. If the splines on the pump are a little wore or not greased well, they will rattle at that RPM. Giving it gas and the noise going away is exactly how it would act. Grease the splines and U-Joint coupler real good, put it back together and idle it at 1000 rpm or better and I'll bet your noise is gone.
    Duane HTP
    Member MAFIA'S-PGE's Avatar
    Default The man in yuma
    go see vic at desert yacht marine! If you are from yuma, you will find him close. He is not only a great guy, he is very knowledeable,and with years of experience you cant go wrong!
    Sep 2008
    Yuma, Az
    Thanks for the replies. It had a little bit of grease on the splines. I'll grease up the joints and add alittle more to the splines.
    I've known Vic for sometime.
    boatless....
    Duane HTP
    x2
