Oiling question BBC
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 43
Oiling question BBC
    Aug 2009
    Default Oiling question BBC
    Engine has 70 lbs. oil pressure but not getting oil to rocker arms?
    Kingman/Golden Vly, Az
    just curious...could the pushrods be plugged up with something?...if your getting oil to the lifters, i personally cant think of anything to restrict oil to the rockers! ...hyd?, solid?, roller cam?
    FastRat
    Aug 2009
    Default Oiling issue
    FastRat
    Hydraulic lifters. I just pulled the intake off and removed all the lifters. I ran the oil pump with a drill, not getting any oil to the lifter area.
    Senior Member bigblock68's Avatar
    what did you use to run your oil pump
    Quote Originally Posted by eliminator cat View Post
    Do you have a distributor housing in place? The housing actually closes a huge leak in the pressure oiling system......The only other thing I can think of is the two plugs in the back of the block. If they're too deep/too long, they could close off the passages.......Ray
    LOUD BOATS SAVE LIVES
    If one of the rearmost valves on each side were open the lifter would restrict the oil passages enough to cause the problem. Did you try turning the engine over 90* a few times while you were priming it.
    Default oil pressure
    I had that happen to me on a small block for when the machine shop put the cam bearings in wrong the oil holes were not lined up
    Default Huh?
    Quote Originally Posted by matt wheeler View Post
    The lifters/rockers do not oil from the cam bearings.....The cam and mains are tied together. The lifters are oiled by the galleries running from back to front, and then up the pushrods, to the rockers......Ray
    Your oil pump drive should be a old dist with the gear ground off, run by a drill. No dist, no pressure.
    Default Roll pin?
    Why not just drive the roll pin out and save the gear?......The top of the shaft needs to be ground/turned down to fit in a drill, but the gear is easily removed....Ray
    okie, lake Texoma
    The inside of the gear is what keeps the oil pump shaft and the dist. shaft centered, without the gear it would wobble apart.
    H8-2-W8
    [email protected] first pass
    Default Well....
    Well I guess you learn something everyday......Although, I've been using one without anything down there for decades without any problems.....There is a bushing in the bottom of the housing that keeps it lined up......Ray
    okie, lake Texoma
    well how 'bout that maybe i'm the one that learned somethin.lol
    Wonder why they even make the gear wrap that joint in the first place then if its not needed?
    H8-2-W8
    The thing you call a gear wrap holds the shaft to the oil pump, then the distributor sits on that shaft silly.
