Is this too much angle?
Results 1 to 14 of 36
    Wet
    Wet is offline
    East Hampton, CT
    Default Is this too much angle?
    I hope not.
    i'm back!! 1QuickCP's Avatar
    Montana
    yes...thats not good at all
    okie, lake Texoma
    Gonna have to drop the engine just a little, keep an eye on the oil pan.
    H8-2-W8
    [email protected] first pass
    The Man cordog009's Avatar
    East Texas
    Yea..way too much angle. Hope you have room to drop the motor some without changing oil pans.
    1984 Youngblood TX-19 SOLD
    Yes. You only want 2*.
    The Right Coast/SE-PA
    Bill, this appears to be what you have now >just opposite. The pump shaft and crank 'may be parallel' but not in line
    For longevity, the below is where you should be. The very bottom example is a 'exaggerated' 2 degrees down on the engine crank > or it could be 2 degrees up too ^
    East Texas
    Yea you want just enough angle to allow the needle bearings to roll.
    Wet
    Wet is offline
    East Hampton, CT
    Shit! Well, I have at least an inch clearance under the pan, so in theory, I should be able to lower it, but I have two options for doing so. Neither one if them are pretty, so which is the lesser of two evils? The rear plates have plenty of material for me to drop the rear. The front plates do not have enough material for me to drop, and still be able to support the front of the engine. As it stands now, there is appx 3/8" material between the fuel pump cutout, and the leg. The plates are 1/2".
    Option 1:
    Pull all 12 rail bolts, dowel the holes, and drill 12 more (offset)
    and lower the package.
    Option 2:
    Cut the rear plates to clearance. Shorten the rails.
    (I have a lot of rail material).
    Use a second, yet short rail system for the front mount? It would be 6 less holes. It would be a stepped rail.
    Quote Originally Posted by Wet Dream View Post
    Option 1:
    Option 2:
    I'd do whatever I could so that I didn't drill more holes in the boat.
    Cut the rear plate down and build a new front one. It will look much better that way.
    X2 The motor and pump should be at approx 4 degrees each with driveshaft offset 1-2 degrees. Is your engine at 4 degrees now. May be you can cut the rear plate down enough to get the driveline angle better. That way you don't drill anymore holes in stringers. I'd remove the rear motor plate, install the driveline , and lower rear of engine and check angle before cutting anything.
    Last edited by Wicked Performance Boats; 05-17-2010 at 09:08 AM. Reason: bad spelling
    Senior Member sleekcraft137's Avatar
    Star, ID
    Option 1:
    Option 2:
    does the front of the motor even need to drop? if you drop the rear and not the front the angle would probably be right where you need it.
    Wet
    Wet is offline
    East Hampton, CT
    The pump cl and crank cl are 1* apart. The elevation is the issue. I suppose I could try to remove the rear plate and see how the motor angle looks to the boat. The OTs have plenty of room.
    California
    As a last resort you might be able to flip the rails, would be a better alternative to drilling more holes.
    Wet
    Wet is offline
    East Hampton, CT
    Good idea, but the holes are staggered.
