Water blowing past place diverter O-ring / PLEASE HELP!!!!
Results 1 to 11 of 11
    Senior Member Dominator Scott's Avatar
    Feb 2010
    Lansing Michigan
    Default Water blowing past place diverter O-ring / PLEASE HELP!!!!
    Okay guys I took the Sanger out yesterday and I have water blowing past the o-ring seal on the diverter near the top pin where it pivots side to side in the drrop snoot. I checked and the o-ring is still there and intact so could it be that the mouth of the droop is getting worn and not letting the o-ring seal good?
    How do I correct this issue?
    Quote Originally Posted by Dominator Scott View Post
    Scott just curious what brand droop is it Tom
    SLOW MEMBER slowboy's Avatar
    Duluth, MN
    The sealing surface on the droop is probably worn a little. I had to build mine up a little with some epoxy. Also be sure the bushings are in good condition.
    Have the inside of droop powdercoated again and hand sand until it fits better. I know because i had some redone and they didn't take first coat off and i had to sand every piece to fit!
    Feb 2010
    Lansing Michigan
    I cant remember for the life of me. I was polished aluminum with blue lettering on the sides.
    Feb 2010
    Lansing Michigan
    Its not a Berkley droop. That much I do know.
    Feb 2010
    Lansing Michigan
    Would that liquid rubber material that you dip tool handles work if I coated some in the droop with a brush or would it just get blown off?
    Also where can I get some of those shims fast?
    It would get blown off. Epoxy or powdercoat will last.
    Feb 2010
    Lansing Michigan
    Epoxy is exactly what I used and its drying as I type. I removed the diverter and the issue stared me right in the face. On one side of the snoot you could actually see a groove on the top right hand side where the diverter o-ring sits. So I filled that area with epoxy and it appears that it will do the trick. I will hit the entire mouth of the snoot with some epoxy paint tomorrow just to thicken things up a bit and put it back together.
    I don't know if it will help but I also smeared some water proof grease on the teflon o-ring just to reduce the friction on the snoot.
    sounds like you got your problem licked. Happy fitting it together.
    Feb 2010
    Lansing Michigan
    Tonight will tell the tale. I let the epoxy dry overnight and hit the mouth of the snoot with some rubberized undercoating just to fill the other slightly worn areas just for good measure. I will hit it with some 800 grit sand paper to smooth the coating and put her back together. I don't know how long the coating will last but I"m not too concerned considering the epoxy filled things in so nice I don't think the coating was even necessary.
