Eliminator Daytona owners
Results 1 to 14 of 24
    Senior Member snake321's Avatar
    Middletown, Connecticut, United States
    Default Eliminator Daytona owners
    How about a measurement from the transom to the back of the block. If anyone has moved their motors with any luck,let's hear about it.
    YOU LIE!!!!!!!!!!!
    Quote Originally Posted by Ultra26 # 1 View Post
    I've been known to be a jackass a time or two.
    The Right Coast/SE-PA
    21' or 19' ?
    I have a 21'
    I set my pump back > but didn't do a "race setback".
    talking about Dream's boat
    stock intake location
    YOU LIE!!!!!!!!!!!
    Quote Originally Posted by snake321 View Post
    huh?
    Spacer...?
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    There are a lot of variables. Ours is at 26 1/2"
    QE 439 Twin Turbo
    Question asked (I think) what's between the front of the pump and where it mounts to the flexplate. And did you keep a straight line following the pump shaft and crankshaft?
    New Port Richey, FL
    Transom to back of the block is what I read. The standard locations to measure.
    There is now way to get the crank in line with the pump shaft using a lopro intake. So we have a 2* angle on the driveshaft.
    QE 439 Twin Turbo
    Understood, what's the length of your driveshaft...pic?
    New Port Richey, FL
    I was ooking for a pic. It's not real short. The pump is set way back and has a jet-a-way. I think it's14" or so. I just bought it you would think I would remember.
    QE 439 Twin Turbo
    New Port Richey, FL
    found this on the memory stick. Not a good pic.
    QE 439 Twin Turbo
    New Port Richey, FL
    one more I have another set of holes drilled to move it up an inch
    QE 439 Twin Turbo
    yep
    YOU LIE!!!!!!!!!!!
    is that a 21' boat?
    YOU LIE!!!!!!!!!!!
