remote starter button...
Results 1 to 13 of 13
    no need 2 fake it. 84Condor's Avatar
    Yuma, Arizona, United States
    Default remote starter button...
    anybody know a local parts house that carries them just to roll the motor over while running the valves? I have one with a trigger that is a pistol grip, but A) can't find it and B) hate it from the last time i used it.. i want one with a button on the top like thisssss...
    http://www.summitracing.com/parts.aspx?sku=SUN-CP7854
    but need it tomorrow night, haha. thanks guys!
    "i'm into snatchin' kisses... and vice-versa!" haha
    Member phil369's Avatar
    N W Ga.
    Snap On Tools has the same starter button, prolly wont help you for tomorrow tho!
    ah actually that might, i know a local rep.. thanks bro!
    460 is offline
    ATTA BOY 460's Avatar
    I think napa sells them
    Orlando.FL
    Auto Zone
    Sep 2008
    Yuma, Az
    harbor frieght has them for around 10 bucks. i have a snap on one you can use. let me know if you will need it.
    boatless....
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    I got mine from Auto Zone. Works great.
    Wags
    What I have done in the past is mount a momentary toggle wired direct to the starter somewhere on the motor kinda out of sight but accessable for running valves starting or what ever. I also have used starter buttons. M
    Sacramento, CA, USA
    That's a good idea as well!
    Wags
    Senior Member StressExpress's Avatar
    Feb 2009
    Menifee, Ca.
    Any auto parts store with a momentary button with some gator clips and your golden.
    Sacramento, CA, USA
    Might be good to hard wire it just incase there's a wiring issue come up between the dash and the engine. At least you could get started and get back to dock.
    Wags
    Feb 2010
    to a point. there should not be any issue in the simple boat wiring that couldnt be jumped with a screw driver. also if you did a hardwire... no need for a key to steal your boat.
    Default wrench it....
    Why not wrench it?......Ring gears last a lot longer when they're not used as a "bump" over tool......The "stopping" place is more precision as well......Ray
    PS I usually install a ignition toggle switch, and a starter button up under the gunnel back close to the engine. Works out well when setting timing, or???......Ray
    LOUD BOATS SAVE LIVES
