switching bowls
Results 1 to 8 of 8
switching bowls
    Salem,Or
    Default switching bowls
    so Im switching over to a split bowl on my tahit daycrusier and Whats the trick to getting at some of the bolts on the inside off the boat that are the bottom of the bowl????. I had to use a breaker bar on the one's I can reach but I dont have much strength in my right hand after having surgery. I guess a 3/4 " swivel socket might work..looks like another trip to harbor freight
    Senior Member sleekcraft137's Avatar
    Star, ID
    Quote Originally Posted by BrotherWolf View Post
    so Im switching over to a split bowl on my tahit daycrusier and Whats the trick to getting at some of the bolts that are the bottom of the bowl????. I had to use a breaker bar on the one's I can reach but I dont have much strength in my right hand after having surgery. I guess a 3/4 " swivel socket might work..looks like another trip to harbor freight
    post up some info when your done. I have a 19 tahiti daycruiser that i will be doing a bowl switch pretty soon.
    Aug 2009
    swivel ,long extension and a impact wrench maybe a wobble end extension
    Senior Member hydroman916's Avatar
    Sep 2008
    sacramento
    take the transom cover off first, you'll never get the bowl out or in with it on
    get blown or get blown away
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    Is your transom plate off?
    Loose, the Dogs of War!
    Q.C./Big River
    Quote Originally Posted by hydroman916 View Post
    X2. Makes thing a whole lot easier. If you don't want to take it off then it will take some serious patience but you CAN get it off. Good luck.
    Do you (or a nice neighbor) have an air compressor? I may be making a run down to that area tomorrow afternoon and can bring my HD impact gun, extensions, swivel etc by for a few min. If you can get air from a neighbor I have 175 feet of hose and a resivoir tank.
    Salem,Or
    Quote Originally Posted by PDX Jet View Post
    Appreciate the offer but Im good now after thinking about it for awhile. I will take the transom plate off first.... I had a brain fart. My buddy gave me is key code to his shop that has the tools and air compressor etc in it. Now I dont have to wait till he is back in town.
    Thanks guys
