Ride plate and angle aluminum
Results 1 to 13 of 13
    Cole SS cole ss's Avatar
    Rochester, wa.
    Default Ride plate and angle aluminum
    I need to add some angle aluminum to my ride plate. What size do most jet boaters use? How many bolts? Has anyone tried JB weld, it seems like that would give a really clean installation. Thanks
    Santa Clarita
    Quote Originally Posted by cole ss View Post
    JB Weld sounds like a great idea...I'd definitely try that.
    Senior Member nosfomoco's Avatar
    Dec 2009
    Sac, Ca
    I used 1 inch angle and it was 1/8 thick. use three bolts to hold it on. I think the only way the JB weld would work is if the plate never bowed because that stuff dries hard. Once it starts to crack I think the pieces would fall right off.
    1978 Eliminator Sport Cruiser 20.5ft BBF 460!
    Glendale Arizona
    Do I detect a note of sarcasm?
    Quote Originally Posted by nosfomoco View Post
    I did the same, but used a few more bolts. 1 bolt every 3" would be plenty. I was having fun drilling and countersinking and put one every 2".
    with your ol lady
    Super glue is cheaper than JB Weld
    No more Mr. Nice Guy !
    California
    I like to use 1" x 3/16" structural angle (not architectural angle), and like Squirtcha said every 3"± is fine. Here's one I just finished for myself the other day.
    Senior Member slow67's Avatar
    DFW
    Why not find a local welder and have it TIGed?
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Sarcasam at its best
    I doubt it would hold up to the beating those plates take
    The Right Coast/SE-PA
    Talking
    And then put your helmet on and wait for the short-bus pick up > and don't forget to lick the windows yummm
    Member propless dancer's Avatar
    norco, CA
    MPD uses 4 pieces of channel and puts bolts every 1.25".
ID:	76226   Click image for larger version.
    Quote Originally Posted by propless dancer View Post
    hmmmm, my MPD plate doesn't have all that, unless it was a special order option I didn't know about
    B1 Racing cs19's Avatar
    The spacing changes on the fasteners on different areas of the plate. There was some engineering behind that setup by Jack and one of his engineering buddies, they did a good job on it.
    norco, CA
    My whole setup came off the cp that you guys did for scott foley. When he crashed the boat I sawzalled the intake out and took everything attached to it. The plate, intake, shoe, and spacers are all top quality hand made chit.
