Taylor`s Jet Boat Roost ?
Results 1 to 11 of 11
    Member phil369's Avatar
    N W Ga.
    Default Taylor`s Jet Boat Roost ?
    Have lost web address for Taylor`s site, are they still there ? Thanks, Phand
    Nov 2008
    Fuquay-Varina, NC
    Quote Originally Posted by phil369 View Post
    www.google.com is your friend
    http://thetaylorboatsroost52059.yuku.com/
    '77 Caribbean
    N W Ga.
    Thanks Storz, Monday morning brain fart, Phil
    Nov 2008
    Fuquay-Varina, NC
    Anytime
    Would love to see some pictures of your Taylor, the SJ is one of the best looking hulls out there IMHO
    '77 Caribbean
    Quote Originally Posted by Storz View Post
    Anytime
    good looking boat, jus heavyyyyy
    don, it was a a cut/ultimate wearring/c-bowl/divertor/stuffer/pro loader/ and hi-tech performance shoe and ride plate kit
    Okmulgee Okla.
    I am looking for a shoe & rideplate kit think I will keep the droop till I can get the kit and experiment a little with it. LOL What I should be looking for is another hull to put this motor in. Oh well push it till It wont push no more, right.
    well the block is GM any ways
    IS UNDER FIRE
    Quote Originally Posted by Wild Hair View Post
    I just put a HiTech add on shoe and rideplate on my LP and it seemed to help alot.
    you'll get so much transom lift with the shoe/rideplate kit that you won't need the droop sell it and buy a hi-tech kit the c-bowl works best on sj's with 12je pumps, you gotta remember that pump is technically at full setback position so adding a droop is jus too much leverage on the hull that should be used to push the boat instead of help lift it c bowl man, no joke
    Sep 2009
    Chicago, IL
    Same bowl suggestion for an SS, no droop as well?
    Quote Originally Posted by PowerAddict View Post
    yep if it has a 12je or 12jf, ss has the same bottom hull as a sj taylor boats are heavy built, they can't be flown crazy high like some other vhulls, its best to concentrate on the push instead of transom lift.
