Ballast Resitor w/MSD
Results 1 to 8 of 8
    Nov 2008
    Fuquay-Varina, NC
    Default Ballast Resitor w/MSD
    Replacing the old points stuff with an MSD "Ready to Run" distributor and Blaster 2 coil, instructions are somewhat foggy on whether I need to continue using a ballast resistor?
    '77 Caribbean
    Senior Member Futs's Avatar
    Orange CA, Big River
    Quote Originally Posted by Storz View Post
    The MSD stuff has an internal ballast and no need for the external.
    your old set up probably had a non ballast coil and therefor the need to run it. They just break down the voltage from 12+v to about 9.6v so it wont fry the points.
    Nov 2008
    Fuquay-Varina, NC
    Thanks, I can just connect the two wires that were attached to the ballast resistor directly together then right?
    '77 Caribbean
    yes, or you could make a new wire lead so there are no breaks in the wire.
    Nov 2008
    Fuquay-Varina, NC
    ah good point, thanks again
    '77 Caribbean
    Glendale Arizona
    Keep it up Tim. You're gonna put the wire splice manufacturers out of business.
    C'mon Dan, Ive seen your wire loom, you got that covered...hahahaha
    Glendale Arizona
    I've got an excuse though................I bought stock.
