holley jets... wtf???
Results 1 to 14 of 30
    "BOUGHT NOT BUILT" 2FORCEFULL's Avatar
    Default holley jets... wtf???
    took the haskel out to mead today, I put a new carb (holley 750 vac. sec,)
    been out a while.. boats runn'n strong...not shoot'n ducks or nothing
    but feels like it's on kill..
    so I pull a plug... sure as shiat... whiter than false teeth...
    I like em with that light chocolate milk color..
    so I come home and dig out my old holley jet box...
    it has 72s... so I'm think'n 74s or 76s
    well, I pull out a couple 74s, just look'n at them the 74s look smaller..
    so I index them and sure enough they are smaller...
    I noticed that the jets with the number on the side are bigger than
    the ones with the number stamped on the top...
    seems like i remember someting about that... but forgot??
    anyone know whats up???
    I ended up putting the 76s in,... and gonna bring the 74s to test tomorrow..
Name:	haskel mill 001.jpg
    I remember when they changed their numbering system Longggggg time ago. Like 20 years. I had a chart that told you what the new numbers were.
    lol... I think my jet box is 30+ years old...
    Quote Originally Posted by 2FORCEFULL View Post
    Mine too.
    Cas
    Cas is offline
    Angry American Cas's Avatar
    not sure if this will help or not but it's a chart showing the current Holley jet numbers and the orifice size-
    Holley measures the jets by flow and not really the size of the orifice. If you look closely at the jets, like 80, 81 and 82 with the same size orifice, they have different entries and exit angles
    The Right Coast/SE-PA
    Thumbs up
    Good post Cas
    Cas
    Cas is offline
    Good post Cas
    thanks! I found that chart a couple years ago, figured it would come in handy someday
    big thanks here Cas...I'm getting old and sometimes I look at something and say...
    "I used to know how to do that"
    well, I run the 76s....she's still lean...
    it came stock w/72s
    how big can I go with out afr problems???
    I'm gonna try 80s and bring 78 with me...
    spokane, WA
    In my experiences it takes a big jump to make a change in a jet boat....I would put the 80's in and start there. Why not just bring the whole jet kit??
    Travis
    I like my women like I like my boats......Fast and ready to get wet at all times!!
    Quote Originally Posted by TwinTurbo540 View Post
    Travis
    the carb is a 750 vac, secondary... came with 72s= .079
    80s would be .093
    i have some .103s
    how big of jet can you run in a 750?
    B1 Racing cs19's Avatar
    To do an accurate plug reading you need a plug reading tool like a doctor uses to look into your ears. You need to be looking deep down the porcelain and looking for a fuel ring. Pulling a plug and just looking for a chocloate milk appearance is NOT the way to read a spark plug. White porcelain is a good thing as long as you have a little fuel ring down at the bottom.
    Your jetting may be ok where its at.
    Default Diameter vs AREA
    Granted, the numbering system changes are needed, new to old, but truth be told,
    there is a much better chart that shows actual "area" of the various diameters. When dealing with air density, tuning corrections are done on a percentage basis. Example: the .093 jet has an area of .0067929, where the .079 has an area of .0049017........Once you establish a performance "baseline" at a given air density, and flow area, you can easily reach the same F/A ratio using density change percentage, to area change percentage, to a "gnat's ass"........Without having to stop and do the conversion math from diameter to area.......Just saying, when you're looking for that last ounce of HP.......Ray
    PS This is extremely helpful when running at different altitudes, or changing weather conditions....
    LOUD BOATS SAVE LIVES
    I tryed at the lake with a magnify glass with the sun shinnig down in there,
    nothing...
