colorsanding my 76 tahiti
Results 1 to 12 of 12
    Senior Member sleekcraft137's Avatar
    Star, ID
    Default colorsanding my 76 tahiti
    So i tried wax.....nothing! i tried buffing....NOTHING!! so i decided to color sand......ITS WORKING!! So I got one side of the boat done, i hope to get the other side done tomorrow
    Driver side, washed and waxed !!(not color sanded)
    other side color sanded and polished
    Small Block Rockin' SJ-16's Avatar
    Jan 2010
    Far East Texas
    Quote Originally Posted by sleekcraft137 View Post
    I am wanting to start working on my Cimmaron's oxydized gelcoat. If I may ask, how did you do the color sand process, and what products worked for you?
    Star, ID
    Quote Originally Posted by SJ-16 View Post
    i cleaned the area with soap and water. first i used 1000 grit wet sand paper, then to a 2000 grit wet sand. then meguairs oxidation remover using a porter cable 2474 polisher on med speed with a cutting pad. then followed up with meguairs polish with a finish pad high speed(also with the porter cable polisher)
    i tried using my claybar/high end waxes but they just didnt cut into the gel coat enough. So i went with the stuff that was ment for gel coat. Why waste my expensive stuff if it wasnt working?
    Senior Member nosfomoco's Avatar
    Dec 2009
    Sac, Ca
    It looks good!!! Keep up the good work!
    1978 Eliminator Sport Cruiser 20.5ft BBF 460!
    Star, ID
    Quote Originally Posted by nosfomoco View Post
    "work" thats the key word! I think it'll be worth it in the end, it just sux getting there
    Senior Member jet460's Avatar
    Mar 2010
    Modesto, Ca.
    X2...waxing is the easy part.
    It's the sanding and polishing that will make it look good.
    The wax just glosses it up and protects what's under it.
    My boat was very oxidized, like yours, and after just an afternoon of buffing, and then a quick coat of wax, it came out like this.
    Salem,Or
    wow thats looking great
    Jan 2010
    Far East Texas
    Thanks Sleekcraft. My wetsanding is done, but current compound seems to be too light as you mentioned. Going to the big city today, and will stop by the boat dealer as they carry the Meguairs products.
    Go to a pro paint store, Get a DuPont cutting grid like a seven, stay off the corners, then to a polish, then a Black Magic or equiv, then a Wax. the 2000 should be an easy polishout, remember its sand in the polish so don't burn or go deep. It looks good what you have done.
    Star, ID
    yeah i tried the rubbing compound as well and it just didnt seem to do the trick. Be sure you have a few cutting buffing pads, they'll turn black and just get pretty nasty lookin! On the good side of that you will know that the product is working.
    Ralphs club member LSXINDUSTRIES's Avatar
    Dec 2009
    Van Nuys, CA
    I need to do this to my boat. Was your gelcoat looking "cloudy", like it had a layer of crap over the surface? thats what mines doing. Ive got the same "wood grain" gelcoat, mines a 22ft 1975 spectra-copy mini-day cruiser.
    “I am on a drug. It’s called Charlie Sheen. It’s not available because if you try it, you will die. Your face will melt off, and your children will weep over your exploded body.”
    Star, ID
    Quote Originally Posted by LSXINDUSTRIES View Post
    yeah it did have a cloudy appearance as well as a grey film on the metal flake.
