wiring gurus help needed
Results 1 to 13 of 13
    Default wiring gurus help needed
    This is my first time wiring a boat. please tell me if i have any errors.
    I already have the wire size figured out and there was only 9 wires in the boat previously. (should be easy, i know)
    • The hot lead goes from the alt (1wire) to one post of the ammeter and the other post, to the battery.
    • should the ammeter post be the one i use to jumper the hots to the other gauges?
    • The distributor has a pertronix in it with red and black wires coming out. these go to the coil.
    • I still have to figure out how to wire up the msd box.
    • for the bilge pump, its an auto and has the 3 wires. do i connect the 2 positives together to wire it to a 2 pole push pull switch? Also the IGN. switch is a 3 pole, so how would i wire the bilge to be on even if the key is off?
    Glendale Arizona
    I'm no guru, but maybe this will help.
    The hot lead goes from the alt (1wire) to one post of the ammeter and the other post, to the battery. Should the ammeter post be the one i use to jumper the hots to the other gauges?
    First off the gauges should be wired up to key'd 12 volts (not always hot) so they only work when the key is on. When it comes to jumpering, it's jumpered, and doesn't matter where it starts or ends at. It's going to be keyed 12 volts everywhere it's hooked up. Personally I'd dump the ampmeter and go with a voltage gauge.
    That part is incorrect. See the photo below.
    Here's a link on how to hook up an MSD to...........well anything just about.
    http://www.msdignition.com/uploadedF...DTN_pn9615.pdf
    There's a wiring diagram on the back of the box. Or you can follow the link I put up. Basically the heavy black goes to ground (engine block or battery). Heavy red goes to + post on battery. Light weight red is key on power (+12 volts when key is in run position) usually purple wire from dash). Tach connects to the end of the box (where it's marked tach). The short two wire connector is for the distributor. Light weight orange and black go to the coil + and - respectively..
    Also a wiring diagram that comes with the pump. If it's a Rule, here's the way I do mine though. Disregard the brown wire with the white stripe. Connect the black wire to engine block or battery negative (ground). The only wire left (brown) goes to a switch on the dash that has 12 volts on it all the time (not keyed, but always hot) usually will be a heavy red wire at the dash. When you're on the water leave that switch on all the time. The pump will kick on only when needed (flipper switch), or every 5 minutes (electronic) depending on what kind of automatic pump you bought. When you get off the water, turn the switch off.
    You can accidentally leave it on for days literally and it won't drain the battery. Automatic Bilge pumps use very little power. I've left mine on in the garage for a whole week once and it didn't drain the battery.
    Did you use the correct wire colors, or just pick some out? There might be some color descrepancies in the information above if you didn't use the right ones in your wiring.
    This is for a Pertronix module, not the distributor, but it should be the same. Page 41 in the manual link I put above.
    Senior Member Futs's Avatar
    Orange CA, Big River
    That about covers it......
    Senior Member slow67's Avatar
    DFW
    If the Bilge is a 3 wire, it probably has an internal float switch (will come on if the water is too high whether the key is on or not) and a manual over-ride (force it to come on, key on only)
    When you see me this weekend Dan, flag me down, I owe u a beer margarita or jäger bomb
    Glendale Arizona
    Quote Originally Posted by slow67 View Post
    This what I assumed he had. They're pretty freaking cool and work better than the float switch ones IMO.
    Rule Pumps 12 Volt DC Automatic Bilge Pumps 500 GPH - 2000 GPH feature computerized operation on the principle of impeller resistance. Float switches are not required. The pump will turn on every 2-1/2 minutes to sense for water. If water is present, the pump will sense resistance and continue to run until all the water is removed. Thereafter, it will check for water every 2-1/2 minutes.Power use in the checking mode is minimal.
    Quote Originally Posted by sandeggo View Post
    You might want to wait until it's all running.
    it is the full auto new rule 750.
    I am leaving tomorrow morning if it's ready or not. I can't figure out how to hook up the ammeter
    Member Rogers daycruiser fan's Avatar
    Orange County,CA
    Default Bilge Pump..
    The BROWN wire goes to the switch up front.
    The BRN w/ WHT goes top a constant 12 volt hot from the battery
    The BLACK is to Ground
    Glendale Arizona
    Quote Originally Posted by Rogers daycruiser fan View Post
    The way I use my pump, I don't need the brown w/white stripe. It's so you can turn the pump on manually.
    I just let the automatic feature do it's thing. It's never let me down yet. I don't get a lot of water in my boat anyway.
    I've never run one before, but if I remember right, you have to break the circuit and the ammeter goes in the middle.
    It's like it's a part of the circuit. Kind of think of the ammeter like it's a piece of wire.
    Once again.........I'd ditch that thing and run a volt gauge.
    Or this if it's easier.
    Nov 2009
    Langley, B.C. Canada
    and remember pull your power for every thing but the starter from the alt side of the amp meter this way you see how much is going to the batt and if the alt fails it will read in to the negative to tell you your using more power than the alt is putting out. i will agree ditch the alt for a volt meter. way more effective especially if your sitting around the lake listing to music you wont know till its to late that your out of juice to start the boat. you can still tell if your not charging
    Denton, TX
    Here take a look at this....
    http://www.performanceboats.com//sho...illidie&page=2
    An ammeter is a shunt of sorts. (Quoted by some one else) It's telling you what’s happening between the battery and the Ammeter. The Alt will charge through the Ammeter hence the needle going to the charge side. The ammeter is just connecting the circuit between the two and telling you what’s going on. The Ammeter is ALWAYS HOT, if you piggy back off the Hot post to your other gauges they will be on 24/7. Best way to do it is have the other gauges piggy back off a 12V switched source like the key switch.
    As far as the bilge, I have a Float Activated one. Its 100% automatic (One day that will most likely bite me in the ass) it has three wires, one to ground the other wired up hot and a third Which I don’t use, Brown with white strip if I remember correctly.
    Well a buddy helped me get it all wired and we fired it up and were tuning it, hit the key to shut it off, it keeps running. Pull off both battery cable and it still runs. Then pulled off one lead of the ammeter. It finally shut down. Something isn't run right I just haven't figured it out yet
    Sophomore Member UltraRS's Avatar
    Apr 2009
    Riverside/B.R.
    See if this helps Kevin. The boxes with 50a or 60a are just fuses. Dont worry about those. Double check the connections at the ignition switch. Seems like thats your problem. It kept running cause the alternator kept it running. From what it sounds like it is not wired like this diagram since disconnecting the ammeter would not have shut the motor off. Good luck!!!
