Help!!! with pulling impy
Results 1 to 14 of 16
    Member Bahnerman's Avatar
    Yuba city
    Default Help!!! with pulling impy
    Well Im trying to change out my impy...first I tried using a 2 jaw and that didnt work...then I got the impy tool and got the impy out of the wear ring area and then snap....the collar broke off impy....tried heating it alittle...no movement....so now here I am....Im looking at the imp shaft and looks like Im pulling the impy with the key or vice versa???? cause I can see that took out one of the threads on shaft...and fn up the next one!!!! Can anyone help me!!!! Can this be fixed??? or Do I need a new shaft???
    Thanks in advance
    B.O.A.T - Beak Out Another Thousand
    Anything is for Sale for the Right Price !!!
    the impy is toast, take an air saw or cutter wheel and disect the impy. if you have not fubarred the threads too bad u shoud be able to rethread them. i use a 1-1/4 12 rethreading die to chase the threads.
    Yuba city
    Quote Originally Posted by johnray069 View Post
    Yea its pretty much toast....Im trying a smaller impy....I thought about cutting it....idk...I think ill just have to do that....
    Anyone else????
    Senior Member lbhsbz's Avatar
    Long Beach
    Quote Originally Posted by Bahnerman View Post
    Anyone else????
    You'll have to cut it....when you do, don't cut all the way through. Only cut to about 1/4" or so away from the shaft. Grab a chisel and give a sharp smack to the cut...it should split the impeller hub and crack the remaining material so that it can be removed without damaging the threads/shaft.
    When doing this, be sure to support the impeller shaft as close as possible to the impeller so you don't risk damaging the bearing and so you don't risk bending the shaft.
    Ladera Ranch
    Sounds like it got pissed you were calling it impy.
    Sorry to say but you better check the shaft. Sounds like its already mushroomed on the end. First trick to pulling wimpy,wimpy impy is heat! Depending on the thread area damage it may be fixable.(cross fingers here)
    Senior Member HKROB's Avatar
    It your going to cut it off make the cut on the key area that way if you overcut it all you do is cut into the key.
    Yuba city
    so I cut the wimpy....smacked it with a chisel....it's cracked across....punched in key.....still no luck...WTF??? Wimpy is still riding on threads....still won't budge...even if I smack it from behind wimpy..any other ideas...guess I'll heat it
    Long Beach
    beat the chisel or a flathead screwdriver into the crack to open the crack, then quit being so wimpy and pull it off.
    Yuba city
    Wish it was that fockin easy
    i'm back!! 1QuickCP's Avatar
    Montana
    ok here ya go you dont need to cut it. 1st take off thrust bearing cap and remove all packing. Brace pump front up aganist a block wall or steel beam, put a piece of carpet between beam and pump. now get a nice piece of 4x4 and after removing impellor nut heat impellor,spray with wd40, put 4x4 up aganist shaft end firm and hit with 16 or 24 lb sledge hammer...it will move I have taked apart sea water pumps this way when impellor is welded to shaft,
    i actually made a aluminium attachment for my jackhammer to fit over shaft if sledge does not work. NEVER ever had one not move with the jack hammer shot. Just make damn sure the pump is all braced down ect as you do not want that thing to move at all when ya smack it. Good luck they are a bitch.
    oh if ya want to get fancy and have a BIG press you can also press it apart but actually the shock works really well.
    Prune-Picker
    Calif
    Anyone else????
    Just curious. Did you ever consider taking it to someone who knew what they were doing? Or are you going to keep hacking, pounding, chiseling on it until there's nothing salvageable.
    Cs
    Santa Clarita
    WTF is an "Impy"? I looked all over my pump and couldn't find one in my boat. Maybe I need to get one....how much speed will I gain by adding an "Impy" to my jet?
    Yuba city
    It's off....shaft is fine..just had to clean up a thread.....
