how much is to much ??????
Results 1 to 13 of 13
    MPR FAB southwind011's Avatar
    riverside ca
    Default how much is to much ??????
    how much oil psi is to much in a stock bbc . i put a new pump in and now my psi is way up 60 at idle 90 around 4000rpm . put the same pump in that came out just a new one. the old one was beat up. a millings std psi high volume
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    why did you go with the high volume?
    riverside ca
    thats what was in it.
    Santa Clarita
    Quote Originally Posted by Fonz69 View Post
    Why wouldn't you? It's a serious question BTW.
    Senior Member CK7684's Avatar
    Minnesota
    No need for a HV pump. I'm using a standard Melling and am getting about 80 psi at 4000...
    San Diego, CA
    Quote Originally Posted by southwind011 View Post
    You'll be fine. In my 502 with a mellings HV77 pump I have around 50 to 60 at idle and 80-90 at higher rpm.
    Boat 405.
    Senior Member coonass's Avatar
    Canyon Lake, TX
    sounds like you will be find ......just make sure to warm her up
    what wt oil do you run ?
    riverside ca
    i been putting vr1 50wt for the past few years
    bfp
    bfp is offline
    Top Fuel Jet bfp's Avatar
    ca.
    unless you are running huge clearances there is no need to run that heavy of an oil. lighter synthetics make more power!and flow better. just so you know we run 0w20 in the drag boats. don't do that in a lake boat but 10w30 good syn oil (Lucas,mobil1 ) whatever, will do you just fine.
    Frozen Tundra, WI
    I have had great luck with standard volume pumps
    Never seen the need for the HV
    You really only need 10psi for every 1000rpm right?
    Senior Member UNASHAMED's Avatar
    Sep 2008
    Tucson, Az
    I have .002 clearence in my bottem end. I'm running a standard pump with 20/50
    "Don't make me get my penguin"
    riverside ca
    Quote Originally Posted by UNASHAMED View Post
    what psi #s do you run
    Nov 2009
    Langley, B.C. Canada
    a high volume is going to heat up the oil more as well if it is going over the relief it is going to gain heat just from that plus high pressure going to cause more heat.
