How to take apart a berkely pump?
Results 1 to 14 of 22
    Senior Member neattouch648's Avatar
    Nov 2009
    El Paso, TX
    Default How to take apart a berkely pump?
    Does anyone know where i can find a set of instructions on how to take apart a berkely pump?
    I've looked around but can't seem to find one.
    Senior Member sleekcraft137's Avatar
    Star, ID
    Quote Originally Posted by neattouch648 View Post
    http://www.berkeleyjet.com/
    The Right Coast/SE-PA
    Actually, it quite simple.
    Also Seloc has a book/manual on Jet drives might find it on eBay >http://search.barnesandnoble.com/boo...ean=0893300292
    http://www.berkeleyjet.com/model_12JG.aspx
    I would contact Berkely direct for info or JBP. I have taken apart a few and learned the hard way the wrongs and the rights. Wrongs cost and proper info is cheap!
    Prune-Picker
    Calif
    Ask "Bahnerman" how to do it.
    Cs
    Senior Member jet460's Avatar
    Mar 2010
    Modesto, Ca.
    Seen it done.
    With the right tools(special huge socket, special puller, etc) it takes minutes.
    Without the right tools, well...it won't happen.
    Senior Member UNASHAMED's Avatar
    Sep 2008
    Tucson, Az
    Um take the bolts out
    "Don't make me get my penguin"
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Quote Originally Posted by UNASHAMED View Post
    Salem,Or
    thats the easy part...It's tyrying to figure out why ya got extra bolts and a wear ring when you have it back together?
    Nov 2009
    El Paso, TX
    lol...If i take the nozzle on the back off, then there is a bolt that has a flat-head top on it. Do i have to remove that in order to get the bowl off/?
    also on top of the bowl are two screws, to grease or lube the bearings, do i just put 90wt gear oil in there?
    Funny.... Love the Guy laying down Laffing.... Reading this I hope the poor Guy is not serious... now if so go with the Seloc Book.
    Sep 2008
    Tucson, Az
    A wear ring? whats that
    Quote Originally Posted by BrotherWolf View Post
    Sep 2008
    Tucson, Az
    No, there should be your bushing oil behind that. What exactly are ya try'n to do? Just check it out, reseal, ??. You have to take the 8 5/8 headed bolts off from the suction housing on the inside of the boat to get the bowl off. The suction housing is what house's (lol) the impeller, shaft, thrust bearing, rope seal, ect. There's pretty much 4 peices to a pump. From inside to outside the boat it goes intake, suction housing, bowl, nozzle.
    Mar 2010
    Modesto, Ca.
    Me not have wife.
    Me no wear ring....(groan)
