Scoop air cleaners
Results 1 to 10 of 10
Scoop air cleaners
    Colfax, Ca
    Default Scoop air cleaners
    I bought a, what I call, a snorkel scoop. Are air cleaners used inside? If so, what type?
    Pic later.
    Glendale Arizona
    I just run flame arrestors in mine, but I'm sure air cleaners would work. To be legal you'd most likely need the flame arrestor type from K&N or comparable.
    What color are you going to paint the scoop Tim?
    Senior Member Dogballs's Avatar
    So cal
    Colfax, Ca
    The color is a given!!!!! Not yet painted
    filter, ya don't need no stinking filter, skeeters add octane
    Anaheim Hills
    Flame arrestors only have to be used if the scoop faces the cockpit....legaly.
    I would only use them if they're alot of bugs where you boat. They rape airflow. You can always take them and shed some screen if you wanna run em to keep the buggies out.
    Dennis
    Glendale Arizona
    Dennis
    Thank you. You're right of course. I wouldn't think that he'd be running that scoop backwards though.
    I've always heard that spark arrestors are big time air robbers. I might have to make a couple passes this summer with and without to see if there's any difference via gps and rpm readings.
    Senior Member tx-19's Avatar
    wittmann,az
    i run that scoop with no filters.
    Senior Member PlacecraftTunnel's Avatar
    Wittmann,Az
    Quote Originally Posted by tx-19 View Post
    Same here on both motors
    Senior Member Constant840's Avatar
    Yucaipa, Ca
    Alot of people run nothing. I have my arrestors cleared out. Just the outside screen left. If you look in the scoop it looks legal.
