mercruiser 502
Results 1 to 7 of 7
mercruiser 502
    Sep 2009
    Chicago, IL
    Default mercruiser 502
    Just wondering if anyone knows any info about the merc. 502 shortblock. Would it be an okay shortblock for a jetboat? What gen block is it? 10.2" deck? Its got a factory roller cam, would any replacement roller cam work or is there something special you need to look for?
    thanks
    Sep 2009
    Chicago, IL
    Merlin heads or early block heads won't work with this block will it?
    Also, I'm thinking single 850ish carb would be good, I know this is a discussion within itself, but for a pleasure jet boat would you go single carb with an edelbrock air gap intake?
    Sep 2009
    Chicago, IL
    sorry about these questions seeming silly or rushed, I have been kinda frantic to find parts now that I finally have a little cash, and there's a 502 shortblock for sale, and I want to get everything quickly so I'm trying to figure out what works and what doesn't.
    Should/could this be moved to the on the Dyno section maybe?
    Ladera Ranch
    if its a 502 its probably not a Mark IV block, so you will want to research the issue of bolting a different era of cylinder head on it. Pretty sure there is a simple modification that needs to be made to the head gasket, but you have to know what block it is first. The only 502 I have seen was a Gen VI, but Im pretty sure there is a Gen V 502 as well.
    For now, put the money away and figure out what it is that you need to make that combo work. There are lots of deals out there on motors with decent parts...
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    Check the cast # on the rear, R/H side and ost it.
    I've got a ZZ502, gen VI in a 22' Schiada. Berk 12jg, SS "A".
    Max rpm, 5200, max speed on gps, 65 at sea level.
    Picts in Boat spam under '74 Schiada, jet.
    After edit...
    I went from an 850 cfm, Vac Sec, elect choke to an 800 cfm, Vac Sec, elect choke. Better throttle response and fuel economy.
    $.02
    Loose, the Dogs of War!
    Sep 2009
    Chicago, IL
    thanks for your input guys.
    I know it says 8.2 on it, I can look for more when I see it.
    and I really can't think of a reason why I should go with a tunnel ram on a taylor ss, single carb should give me all the go I need, with better fuel economy right?
    Sep 2009
    Chicago, IL
    really need some help on which cam and heads I'll need
    Thanks guys1
