removing stuck machine screws
Results 1 to 14 of 25
    gets 'em wet ultrajet's Avatar
    folsom, ca
    Default removing stuck machine screws
    I'm trying to remove my rock grate and all four machine screws will not even budge. I can't imagine having to drill for an extractor in such confined quarters beneath the boat. Anybody have any tricks up their sleeve???
    i'm back!! 1QuickCP's Avatar
    Montana
    Quote Originally Posted by ultrajet View Post
    well if they are slot head I fit a socket screwdriver blade to the screw head, like a big gunsmith screwdriver blade.ie the sides of the blade are a perfect fit to the slot. then I take a large 1/2 inch rachett and set a hydraulic bottle jack under it, so if you can follow this the jack is placing upload on the rachett pressing the screwdriver blade into the slot.Then as you turn it the blade wont slip. i made a little aluminium fixture for my jack with a tiny bearing in it so it twists well but a touch of grease works good for 1 set of bolts. These can be a total bitch so best of luck.
    Drilled mine out and retapped them all the way through....If you decide to do this "wear goggles".
    Made In The Shade
    Custom Window Tinting
    Anaheim/BHC- the Shack
    Try an impact driver. They are a must for strikers on car door jambs too.
    turn the boat over it will make drilling much easier, sorry, couldnt resist, sometimes there is no easy solution, have drilled some of those out that have anoded to the aluminum can be a real pain. soaking it in some kind of penetrant oil heavily for a couple days will sometimes help. good luck
    deckboat owner rschap1's Avatar
    Lowell MI
    read somewhere that the BEST penetrating stuff is a 50/50 mix of tranny fluid and acetone.
    Maybe a little localized heat if you got a small butane torch or something like that...then splash some cold water. Sometimes that thermal shock works as good as a hammer blast to the butt end of the screw driver...
    Good Luck
    Senior Member Amango's Avatar
    Sep 2009
    Drill it a little and then use this extractor! they work great you can use a ratchet and socket!
    http://buy1.snapon.com/catalog/item....e=&dir=catalog
    Bakersfield
    Quote Originally Posted by slowride View Post
    That's probably one of my favorite tools, I don't use it much, but when you need it, it's the only tool that will work. Old Ford doors don't come off very easily without one
    California
    Quote Originally Posted by 1QuickCP View Post
    I've done just that, or at least a variation of that. I use a large good quality screw drive (especially if its a Philips) with a wrench point on the hilt and place a floor jack underneath the driver, then carefully turn the driver with a wrench. Once you get them to move they should come out fairly easy. If they're Allen heads it may be drill time.
    Edit: Just remembered your other thread. If this is the AT intake those hole shouldnt be blind like a berk, squirt some penetration oil on the top side and let it wick down into the threads. Also check and make sure they don't have nuts on the top side.
    Senior Member Rain Maker MN's Avatar
    Good luck getting those bolts out….I tried everything that was mentioned in this thread and ended up drilling them out…… if you have to drill them, get something comfy to lay on and get a good quality bit and make sure you are drilling straight…..then prepare for a long drilling session
    Jul 2009
    Hesperia California
    I would soak the crap out of them with KROIL and try a impact driver, sometimes you have to give them a hit to loosen them up, or heat them to break up the corrosion.
    TJS
    TJS is offline
    CT
    This has never failed me in extacting anything from broken taps to bolts. However if it is a clean break below the surface you may or may not have any luck. I have so far.
    Weld a nut to it. Let it cool a litttle and rock it back and forth and it comes out.
    I have never had to break out a drill yet and have been doing this for years.
    Junior Member speedboats's Avatar
    Dec 2009
    weld a large hex key to it!!! Both heats the job and then you have something to torque on!!!
    When replacing these, use machine socket screws!!! (Hex key / Allen key type)
