Engine RPM'S ??????
Results 1 to 9 of 9
Engine RPM'S ??????
    Default Engine RPM'S ??????
    I have an 18' Kona with a chevy 350, Jacuzzi pump with diverter. 202 heads, 501 lift 292 duration cam, tunnel ram intake with dual 600 edelbrock carbs. Running 93 gas. Timing is at 34 @ 3000. It will only turn around 4300 - 4500 rpms. Shouldn't I get more from it? Am I missing something? I am thinking about going with a single 750 holley. Thanks,Tim
    Senior Member chevy's Avatar
    havasu
    The pumps holding it back
    Feb 2010
    i have not become anywhere close to knowledgeable on this yet but you have a low torque engine turning a pump. depending on what impellor you have is going to determine the load on the engine. i have a 396 with a big cam and TR and dual 660's on a jacuzzi and i am spinning at just over 5k
    Feb 2010
    and the diverter i dont think will afect the rpms. it is only a trim adjust if i have understood right
    Senior Member W.O.T's Avatar
    Campo Ca
    Need to Add a BBC Or cut that impeller down
    1200cfm of carb on a 350? hell he might pick up a few hundred rpms goin to a nice single 650-750 dp over the duals, gotta be runnin alil fat up top with that much carb
    Thats what I am thinking. I am going to try a 750 dp.
    Charlotte, NC.
    Quote Originally Posted by ttshock View Post
    My 350 had a 850 DP on it. I cut it back to a 750 DP and im pushing 5300 RPMs at around 65 MPH on a B cut Allum impeller .
    Dont know if that helps but thats what i got.
    Senior Member HKROB's Avatar
    Cam looks alittle to big for the RPM range.
