Stainless impeller question
Results 1 to 14 of 14
    Feb 2009
    MANTECA
    Default Stainless impeller question
    I have a seriously annoying rattle at idle (950-1000 R.P.M.'s). It sounds like the baffles are falling out of the headers. If I give it a little bit of gas and raise the R.P.M.'s to around 1200-1300 R.P.M.'s the rattle goes away. I thought that my flex plate was cracked, or that the starter was dragging on it, but as far as I can tell everything is okay with the flexplate and starter. I have been told by a couple of people that the stainless impellers rattle at idle, so I now have the pump apart and I have found that the impeller keyway seems a little loose, both in the brand new 17-4 shaft and in the berkeley stainless.
    If you are running a stainless impeller does it rattle ?
    Thanks in advance for any help or suggestions.
    Chris
    Senior Member lbhsbz's Avatar
    Long Beach
    I'm curious about this too. "Pump Rattle" is a failry commonly used term, but I'm curious as to what exactly is making the noise.
    If everything is assembled and clearanced properly, the only thing I can imagine making any noise is the thrust bearing since it's designed to have a significant load on it, and maybe at idle there isn't a sufficient load to effectly "seat" the bearing.
    Ladera Ranch
    Sounds like driveline.
    Senior Member W.O.T's Avatar
    Campo Ca
    Make Sure Theres Nothing Stuck In The Impellor. Check Your Flexplate Make Sure Its Facing The Right Way And Bolted On Correctly. Then Check Driveline. Otherwise Id Pull It Apart Before Something Goes Wrong.
    Feb 2009
    MANTECA
    I just replaced the U joints last season because I thought that there was too much play in them. I was told that the non greasable U joints were stronger because they are solid, not like the greasable joints that have the hole drilled through them to carry the grease from the zerk to the needle bearings. After replacing them I found that the new U joints had the same amount of movement in them. The driveshaft that I am running is about 7" long, I had it made and balanced at a driveline shop several years ago and have had no issues with it. The bolts into the PTO were just reinstalled and were tight when I took it all apart tonight.
    Feb 2009
    MANTECA
    Quote Originally Posted by W.O.T View Post
    Make Sure Theres Nothing Stuck In The Impellor. The impeller is on the bench and there is nothing wrong with it, or stuck inside of it. Check Your Flexplate Make Sure Its Facing The Right Way It is the right way And Bolted On Correctly Bolts are there and tight, Socket head allens that are going through the PTO and flexplate and into the ass end of the crankshaft. Then Check Driveline.It is good and tight with newer U joints Otherwise Id Pull It Apart Before Something Goes Wrong It is apart and there seems to be nothing wrong.
    Another side note is that when I disconnect the driveline and run it in the driveway, the noise is not there.
    I am hoping that the noise that I hear is the impeller, but it sounds like maybe nobody else is having this sort of problem/experiance with their stainless impeller.
    Thanks for the input and suggestions,
    Chris
    Massachusetts
    I was told this is normal. If you don't like it you can turn up the idle speed. Mine has always made a rapping / vibrating sound that comes and goes at idle. It doesn't seem to matter if it new, rebuilt, or on it's last leg. It sounds awful.
    Real Boats Don't Have Propellers!
    -- Rivernut
    Okmulgee Okla.
    Mine made more racket than I could put up with. When I rebuilt the pump I changed the shaft as well, and then decided to change the splined end of my drive. so far I have had a quiet pump I think my noise was comming from a worn spline or drive as I no longer have that problem.
    well the block is GM any ways
    IS UNDER FIRE
    Wet
    Wet is offline
    East Hampton, CT
    I've head the same thing about the thrust bearing at idle.
    Shell Knob, MO
    Thrust bearings in good condition don't rattle at idle. Loose or worn splines on the shaft or U-Joint yokes do. They can also rattle from not having enough grease in the splines. The amount of overlap that the camshaft has and the added weight of a stainless impeller magnify the problem, so just turn the idle up to 1200 rpm and it will usually go away.
    Duane HTP
    Sacramento area
    Talking Rattle
    I've heard this is a sure sign that the impeller detailer didn't know what he was doing. lol
    Feb 2009
    MANTECA
    Quote Originally Posted by schick View Post
    That is a possibility, but like the guy that detailed it would say If you asked him about it..........What makes you the pump expert.......lol I guess that is why I havent asked him yet.
    Feb 2009
    MANTECA
    Quote Originally Posted by Wild Hair View Post
    I will have to take a look at the spline I bet that is what it is. Thanks, Chris
    Feb 2009
    MANTECA
    Duane HTP
    Well, It seems to be a loose spline, and maybe a lack of grease on the splines. I can feel a slight movement between the splines and the shaft. I think that I will try to grease it up and if the rattle does not go away I will break down and buy a new yolk.
    Thanks for all the help
    Chris
