Unilite Dizzy BBC
Results 1 to 2 of 2
Unilite Dizzy BBC
    Dallas, TX
    Default Unilite Dizzy BBC
    My boat came with a Mallory Unilite in it. Just put in some new headgaskets and got the distributer back in. Went to set the timing at 34° at 2k and found it keeps going up. Did some reading and it seems there is 24° advance built in. So should I set it at 10° or what? Its not really clear on that everything else I have ever messed with is computer controlled Fords. Motor in question is a 454 BBC
    You probably need to go closer to 3000-3200rpm before the advance is all in. Set it to 10 degrees at idle and then check total. You should also confirm the RPM at which total is reached.
