What is a 502?
Results 1 to 14 of 23
What is a 502?
    AAARRRRRGGGGGGG!!!!! Motomatt68's Avatar
    Nov 2009
    Default What is a 502?
    I drove up to Oregon this weekend to pickup a new (new to me) boat. It is an aluminum boat built for rivers and whitewater. The guy I bought it from knew very little about boats. He told me he had no idea what kind of engine it had but his brother thought it was a 454. I had him send me a picture and it looked like a 454 in the picture. When I went to pick it up I noticed the paperwork said that is was a Chevy 502. I know small blocks more than anything but I have never worked on a BBC. Is there a difference that is visible from the outside? Is this something that is done to a 454 (bored and stroked) like a 383 is from a 350? Should I be scared?
    Because of this purchase I have put my other project on hold. Really my wife got sick of me constantly working on the boat and not doing anything fun so she told me to buy a good one that works! (she is the best wife ever)
    Matt.
    Renegade jet tunneljet's Avatar
    Shorewood Il
    A 502 is a great motor. It uses the same 4.0 stroke as the 454 but it has a bigger bore. Most parts should interchange with a 454.
    Shell Knob, MO
    Instead of having 7.4 on the block, it will have 8.2 on the block/
    Nov 2009
    Where do I look on the block for the 8.2?
    So a 502 is an actual production motor? Not a "hybrid" like a 383?
    Matt.
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    You got it
    http://www.gmhorsepower.com/ZZ502-Deluxe-Assembled.php
    When built right they will make some serious power
    Member hollbrow's Avatar
    South Ga.
    Yes- the 502 is a GM manufactured High Performance crate engine. It has the good stuff in it.
    Senior Member wolfie's Avatar
    Wow...I thought a 502 was a section in the California penal code about drunk driving. You learn something new every day.
    Cas
    Cas is offline
    Angry American Cas's Avatar
    Chevy has 4 502's with different HP ratings.
    http://www.gmperformanceparts.com/Pa...l.jsp?engine=4
    not sure how you can check to see which one you have although it's probably not the RamJet
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    So the parts from a 454 are interchangable with a 502? So i can take my 4.25" crank + rods and make a 533CID?
    [email protected]
    Ohio
    I think you would need an adapter so your 2 piece rear seal would work.
    Tim
    spokane, WA
    Lots of guys look for the 502 blocks to do a 540. I had a 502 in my first jet boat, a sleekcraft sst tunnel and I ran it hard all day long with zero issues.
    Travis
    I like my women like I like my boats......Fast and ready to get wet at all times!!
    classic hot boater Orange Peel's Avatar
    Mt. Island NC
    Default 502
    I had a 502ci/502hp crate engine it was a great engine, I changed a few things and added a 420 blower she did 747hp 803tq on the dyno..
    I think you will be happy with it..
    Does it have alum heads?
    Never forget where you come from,no matter where you are going.
    Shell Knob, MO
    We just put in a HTP stage III roller cam and did some head work to my grandson's 502 and it made 651 hp on the dynp at 6300 rpm on 91 octane with a Gary Williams 950 cfm carb. Strong motors. Duane HTP
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    ZZ502 in my Schiada jet daycruiser. I've had it since '03. No problems, no issues. I love the torque. SS "A" imp in a 12jg.
    Loose, the Dogs of War!
