Water psi questions
Results 1 to 8 of 8
Water psi questions
    Feb 2010
    Default Water psi questions
    I finally got my boat together yesterday and when I ran it i went to set the water psi and did not build any psi at the manifold.
    My set up is inlet-dump valve-headers-engine. The outlet from the thermostat divider has two 5/8 lines straight out the back of the boat.
    I installed a water psi gage in the manifold and it is a 0-100psi water pressure gauge.
    The engine runs at 160 and their is plenty of water running out of the t stat.
    Are the 2 5/8 lines big enough so i don't need the dump valve?
    If the temp is staying consistent then is everything ok with no psi in the manifold?
    Lake Havasu az.
    Quote Originally Posted by Tahiti18 View Post
    2 5/8 dumps...yep...no pressure..i believe one is supposed to dump and the other is for the headers
    Sheriff Joe Arpaio
    The Right Coast/SE-PA
    Hmmm, zero psi could cause steam pockets in the block/heads.
    I use two dumps out the back yet hold about 9 psi at the manifold.
    High Performance Marine ARS Marine's Avatar
    Feb 2009
    Morris,Illinois
    Any more problems with Milk in the oil?
    Lets see some pics of the Ride!!
    We usually use a 0-30 gauge on the manifold, are you still using the bypass regulator setup?
    Glad to here ya got it wet.
    I take the water for my headers from the back of intake manifold and have 2 overboard dump # 8 from thermostat housing with no gate valve. But i have a 6-71 supercharger with my build a little more heat. Works perfectly.
    Feb 2010
    Quote Originally Posted by ARS Marine View Post
    I am still using the bypass set up, but its not doing anything, i had to adjust it to get water flowing to the engine, then i kept an eye on the gage from idle to wot and the gage wasnt reading any psi.
    could the problem be the range on the gage? is a 100 psi guage not sensitive enough to read at the low pressures?
    I was goin to get a 0 to 30 and see if that picked up a reading???
    Feb 2009
    Morris,Illinois
    The 100# gauge is a bit large for reading such a small amount of pressure.
    When we set up boat's with around 700 H.p. and a tight pump, the bypass regulator seems to hold the W.O.T. pressure in the block under 15# and still has water flow @ idle.
    Hope this helps
    Say Tahiti18 The seats in that boat are what inspired me to make a fiberglass version of the same design.
    Those are 100% Top Notch seats!!!
    Feb 2010
    thanks that does help. ill go get a 0-30 psi gauge and try it.
    the seats are nice thanks for the compliment.
    but i need to make some mounts for them.
    did u get my pm?
