Driveline Clearance Question
Results 1 to 9 of 9
    Wet
    Wet is offline
    East Hampton, CT
    Default Driveline Clearance Question
    When setting the depth on the driveline, do you just slide the yoke on and then back it a little, or do you tap it down and back it off? I've always tapped it down, then back it off. I like as much spline to mesh as I can get.
    Wet
    Wet is offline
    East Hampton, CT
    Over 50 views, and I get the 50 guys who have never set an engine.
    Senior Member UNASHAMED's Avatar
    Sep 2008
    Tucson, Az
    not really get'n what your wanting to know? Are you talking about sliding the driveshaft onto the pump shaft? If so you want at least a 1/4 of play between the housing and the driveshaft.
    "Don't make me get my penguin"
    Senior Member miketeast's Avatar
    maryland
    Quote Originally Posted by Wet Dream View Post
    what you doing 'tappin' in the yoke onto the splines in the first place.
    This dont sound right. A new yoke and shaft are nicely tight, but there is still clearance. The yoke lands against the snapring, i think. After a few runs it will get a little looser, but it shoulnt bind. Must be a bugger on it or something. Is there a relief hole? Maybe hydraulic binding by the grease and that is why it is so tight? I believe mine is open at that end.
    and you need at least as much clearance as is necessary to remove the driveshaft without moving the engine.
    I think i remember that there are about 2" available spline and that it was 'common' knowledge that you needed at least 1".
    With the amount of torque you are putting on it i would go for as much as possible too. (thats right the yoke/shaft splined interface dont give a f**K about horsepower, only torque.
    overgrease the bearing while you are at it.
    Team FTL
    Horsepower Homo
    Centistoke Fag
    Wet
    Wet is offline
    East Hampton, CT
    So 1" engagement is acceptable?
    Feb 2009
    MANTECA
    NO...... I just left the driveline shop looking for a new yolk because mine is loose on the shaft. The professional at the driveline shop says of the 2" make sure you have at least 1-5/8" engaged. He also went on to say that insufficent engagement will cause premature failure.
    Hope this helps you out.....
    Chris
    maryland
    no, not in your case. I like the 3/8" mentioned above. I only have 1/4"...just enough to get the driveshaft out without moving the motor, and of course, to prevent any thrust on the motor produced by the pump.
    what i seen, the larger the angle the more there are micromovements on that splined shaft. If the shaft and motor arent parallel there is a great deal of micormovement (and vibrations) and wear happen much faster. I use mercruiser spline grease on mine. Cant tell you if it does any good. I dont let it touch the bearing or bearing grease though.
    When i grease the bearing i pull the shaft and pull out the old grease with my finger. Keeps the temps from rising so much after greasing it.
    Might i suggest a strapon? Been using one for years on the bearing housing. Very revealing.
    Team FTL
    Horsepower Homo
    Centistoke Fag
    Wet
    Wet is offline
    East Hampton, CT
    I have 2 strap-ons!
    Sep 2008
    Tucson, Az
    Mine came built on hahaha
    I have 2 strap-ons!
