Pump question
Results 1 to 3 of 3
Pump question
    Second Chance unpredictable27's Avatar
    Angry Pump question
    Just rebuilt my 12 jg and found out that the bushing in the bowl was bad. But it's been bad for awhile so it oblonged the hole where the bushing goes. Is there someone or somewhere I can take it to that can fix it or do I have to buy a new one?
    If the rear bowl bushing bore is indeed oblonged it can be repaired with a oversize sleeve , this will however require line bore of the bowl Tom
    * probably just as important , whats the condition of the pump tail shaft?
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    If the shaft is bad it can be fixed by a kit from HI-Tech performance
    Lots cheaper then a new shaft
    http://www.hi-techperformance.com/im...ve.jpg%201.jpg
