Holley 4160 question
Results 1 to 6 of 6
    Senior Member jet460's Avatar
    Mar 2010
    Modesto, Ca.
    Default Holley 4160 question
    My boat has dual 4160's (450cfm)
    The other day at the lake, the rear carb flooded out so I came home.
    Fuel was pouring out of the front bowl vent tube as soon as the pump was on.
    I have an electric pump from summit.
    7psi/90gph.
    The front carb has no problem at all.
    Changed the needle/seat today.
    Float was fine. Not sunk or anything like that.
    Set it the same as the other carb.
    With the new needle/seat, it does the same thing.
    Just pours all over the place like there is no needle/seat at all.
    Not sure how this can happen...
    Got Circus Midgets??? BIGAMIST's Avatar
    S.F.V.
    Had the same thing happen to my 450s....on the 3rd new needle & seat the problem was solved.
    When I die I want to go nice and peaceful in my sleep like Grandpa did, not screaming like the other passengers in His car.
    Mar 2010
    Modesto, Ca.
    I rebuilt both about a month ago, so this is the second new needle/seat.
    I'll try swapping with the other carb and see what happens.
    These things are pretty old, so I almost have a good enough excuse to go buy new 650's..
    Quote Originally Posted by jet460 View Post
    I am by no means a carb guy but have you checked to make sure the float isn't filling with gas?
    Nevermind I just reread your post.
    Mar 2010
    Modesto, Ca.
    I just swapped the needles front to back. Same exact problem.
    Fuel pressure is actually 12psi, which probably answers my own question.
    I guess I have been lucky this did not happen earlier?
    Mar 2010
    Modesto, Ca.
    Thanks to a piece of good advise from Bell&Gaines, I took out the check ball/spring from my Summit fuel pump, cleaned it off, put it back in...now I have 5-7psi instead of 12.
    Problem solved.
