starter bumps but no start
Results 1 to 14 of 34
    Aug 2009
    Default starter bumps but no start
    every once in a while my staRter will bump the flywheel but wont engage and spin...so ill bump it a couple times and wala away it goes. brand new optima blue top and jegs pro starter..it turns very strongly when it does engage.any ideas??????many thaNKS
    proper shimming is the first step....
    http://www.marinemechanic.com/site/page169.html
    Glendale Arizona
    If I'm not mistaken, he's running a 532 cu in Ford. Different animal.
    Nov 2009
    Langley, B.C. Canada
    is it a Bendix style starter (centrifugal activation) if so and it is probable a solenoid, but it could not be bumping the fly wheel with out turning, if it was this style of starter. if for some reason you have a solenoid activated starter it is not meshing properly. so here are some questions, what changed, a new ring gear, hows the wiring original, or new, what kind of starter is it i would assume it is a Bendix style, what is it doing, does it spin at all, slowly, does it grind, go in then jump out, does it turn engage then stop turning?
    Heck theres the problem
    Glendale Arizona
    O.k. I'm a Ford guy and that's still funny.
    Done.... So.Bay*310*'s Avatar
    So.Cal
    I'm having the SAME DAMN PROBLEM! My buddy just reminded me to check spark plugs. See if the tips are smashed. I ran into this same problem that Tim (futs) pointed out last year with my chevy. Had incorrect size plugs.
    Southwest corner AR
    I had this same problem and I found that it is a voltage drop problem! Most boats have the power source mounted in the back of the boat. Then the wiring runs all the way to the front or dash then back to starter! This is famous on BBC's Ford's not as common! Two ways to fix 1 use a Ford style solinoid as a slave with a jumper at starter! 2 rewire the starter to have a hot wire of a large size to carry the voltage needed to make the solinoid hit every time! I hope this helps! WT
    WT
    WFL Crew!!!
    Aug 2009
    now that sounds like it could be the problem ...it currently has a small wire going to the solenoid ...thanx mike
    Southwest corner AR
    The Ford solinoid is the best way! IMO! And easy less wiring! WT
    WT
    WFL Crew!!!
    pull out the bendix, make sure your fully engaged, and more so not over engaged.
    High Performance Marine ARS Marine's Avatar
    Feb 2009
    Morris,Illinois
    X2
    Also we take a small 1/8 " die grinder and put a small radius/chamfer on all the teeth of the ring gear, Really helps eliminate alot of problems.
    Just my 02 cents!
    Senior Member Skydog's Avatar
    Jul 2010
    My BBC is doing just this, every 6-7 starts the starter will spin and not be engaged to the flywheel making a nasty sound. I put a brand new starter on it, same thing. The start is a bottom mount with zero shims. I dont think it is a shim problem, when it does engage the flywheel, it sounds great. What you guys think?
    Thank you
    Jul 2010
    Quote Originally Posted by ARS Marine View Post
    X2
    Just my 02 cents!
    Nice taking to u and great info!!!!
    Thank u Matt
